August 29, 2026, 12:18:42 pm
Hoffman Amps Forum image Author Topic: Shielding a speaker?  (Read 7086 times)
Offline 3choplex
« on: July 19, 2013, 12:38:06 am »
I've been working on an old Gibson Scout lately. The other day I put in a speaker, a 12" Pyle Driver. Everything says the Scout had a 10", but the baffle is cut for a 12", shrug.
With the speaker in, the reverb is humming like crazy. I've moved the tank around, the only place I lose the noise is a couple of feet from the speaker. Is it possible to create a shielded bag or something, or am I going to need to get a different speaker with a smaller magnet? Ideas?
stratele52
  • Guest
Re: Shielding a speaker?
« Reply #1 on: July 19, 2013, 03:42:58 am »
Gibson Scout is a vintage amp . Why don't you keep it as most original you can ? Don't loose your time with 12 inches Pyle speaker ( are they good those speaker ? ) and trying to shield reverb tank.
Put a good 10 inches .
Offline 3choplex
« Reply #2 on: July 19, 2013, 09:36:49 am »
I got the amp free, not working and with no speaker. The baffle was already cut for a 12", so I put in one. :)
« Reply #3 on: July 19, 2013, 09:46:01 am »
I got the amp free, not working and with no speaker + With the speaker in, the reverb is humming like crazy.
As stated, this is not sufficient information to conclude that the speaker is the problem.
stratele52
  • Guest
« Reply #4 on: July 19, 2013, 10:03:29 am »
3choplex , are you sure you reverb tank 's wire have good shield ?
Even with a 10 inches speaker , your reverb tank wiil be too close from the magnet if you need few feet. So it is probably not the speaker's magnet  your problem but a defective ground on the reverb tank or their cables .
Have you check that ?,
With no reverb tank is the amp work well ? If not fix it before go farther.
« Reply #5 on: July 19, 2013, 11:15:18 am »
I don't think the speaker is "the" problem. Something else is amiss like the wire shield isn't grounded or the tank isn't grounded properly. I think it's some other issue even maybe the reverb tube has gone bad?
Offline 3choplex
« Reply #6 on: July 20, 2013, 09:26:49 am »
I did a little test this morning, removing the speaker. You guys are right. It's not the speaker. I'll start checking other stuff. Thanks.
stratele52
  • Guest
« Reply #7 on: July 20, 2013, 09:39:41 am »
+1
I was shure of that .
Offline 3choplex
« Reply #8 on: July 20, 2013, 01:33:15 pm »
I just realized I didn't give all the information in my original message. The reverb was quiet when plugged into an external cab, then when I installed the speaker in to combo cabinet I got the noise. Apparently unrelated, but that was why i was attributing it to the speaker. It was the only thing that (I was aware) had changed. Just mentioning so I don't appear crazy.  :smiley:
stratele52
  • Guest
« Reply #9 on: July 20, 2013, 02:03:17 pm »
Reverb cable and reverb tank look to be good so  !!!
IMO , the noise have nothing to do with the reverb .
Can we just say ; the amp is noisy ( with speaker in ) ?
Ok noisy amp ;
1- more volume = more noise ?
Yes;
a) check with guitar plug in , guitare volumes to "0"
   No Noise ; defective or no input shorting jack
   Noise ; check tubes , ground . Some of Gibson amp don't have heater center tap ; this make noise . Make an artificial center tap with 2 X 100 ohms resistors
Do you have the schematic ?
stratele52
  • Guest
« Reply #10 on: July 20, 2013, 03:18:53 pm »
Gibson scout is a GA17RVT
www.gibson.com/Files/schematics/GA-17RVT%20Amp%20Scout.pdf
Schematic show there are ;
1- No heater center tap ; = noise,  install 2 X 100 ohms
2- There is 2 input shorting jacks ; Check if they work , if go to ground with no guitar , contact often dirty = noise.
3- No three prong AC cord ;= caution electrical hazard and noise;  Install one ,
4- Check for unmatched output tubes = noise
