September 08, 2026, 04:22:21 pm
Hoffman Amps Forum image Author Topic: Transformer in old Magnifying lamp  (Read 7628 times)
Offline rafe
  • I have tube amps
« on: July 24, 2013, 11:16:19 am »
I have an old round flouresent magnifying lamp that cooked it's asbestos and masking tape shrouded transformer yesterday, I use it a lot and would like an easy fix ....does anyone know what the transformer could be replaced with? I have researched a bit and the one being repaired are newer...the asbestos dates it as old....gotta hold down the start button weighted base ...I really don't want to lose this...Great when working on an amp or other small parts Thanks in advance R
Rafe
Re: Transformer in old Magnifying lamp
« Reply #1 on: July 24, 2013, 11:30:04 am »
It's not quite a transformer. It is a choke to limit current plus maybe added taps for heaters. The catalog word is usually "ballast".
They are semi-standard generic. Number of tubes. Type of tube start (starter, quick, rapid). Tube wattage. That gets you to a replacement.
1000bulbs
HomeDepot
Odds are that the replacement will be transistor instead of iron-based.
« Last Edit: July 24, 2013, 11:35:25 am by PRR »
