August 29, 2026, 12:17:50 pm
Hoffman Amps Forum image Author Topic: Reverb transformer  (Read 5784 times)
Offline Medman
Reverb transformer
« on: August 10, 2013, 07:28:14 pm »
I am building a revibe. Why is the reverb transformer  from 6g15 different ?
Thanks JP
Re: Reverb transformer
« Reply #1 on: August 10, 2013, 09:07:13 pm »
The reverb transformer does not need to be different for a revibe versus a 6G15. Any single-ended OT for a 6V6 should work for either unit (assuming you are driving the reverb with a 6V6), so thats something like 5k to 8k, depending on the voltages you're running for the 6V6. After all, the reverb driver side is basically just a variant of a fender champ.
« Reply #2 on: August 10, 2013, 09:44:50 pm »
The built-in reverbs used a small tube (12AT7) with a small high-impedance (15K-25K) transformer.
The stand-alone reverb used a big tube (6F6/6V6) with a larger transformer of somewhat lower impedance (5K-10K).
The "big rig" hits the spring harder, you get more out of the spring, allowing huge surf with not so much hiss, or moderate reverb with hardly any hiss.
Probably if the "big" reverb were stuffed "built-in" to a complete amplifier, the heat weight and cost would be excessive.
You could re-design the Revibe to use the smaller 12AT7 and small RT from built-in reverb designs. Save a buck or three. Hardly worth it since it's the same case, nearly the same power supply, etc.
Offline Medman
« Reply #3 on: August 10, 2013, 09:56:46 pm »
Confused One says yes and one says no? Their is a difference  of 18.00 to 30.00. Not much but my profit goes down. Help
« Reply #4 on: August 10, 2013, 11:35:57 pm »
They are talking about two different comparisons. Tubeswell is discussing the two units you asked about, Revibe versus 6G15. The reverb portion of the Revibe is just like a 6G15. Transformers are the same.
PRR was comparing a typical Fender built in reverb circuit such as found in a Super Reverb amp to the 6G15. Totally different circuits that use totally different transformers.
When you say there is a difference of 18.00 to 30.00, which two transformers are you speaking about?
I recently built a Revibe and I used Weber's W022905 transformer. Cost $25.00
« Reply #5 on: August 11, 2013, 12:08:50 am »
bought one these a couple of years ago to build a 6g15. still sitting on a shelf...somewhere...  :BangHead:
