August 29, 2026, 01:13:04 pm
Hoffman Amps Forum image Author Topic: Fender Blues Junior ~Distortion~  (Read 5598 times)
Offline TerryD
« on: August 12, 2013, 09:03:34 pm »
I'm getting low volume distortion, sometimes ghosting and sometimes just willy nilly.  Any idea what it is?  Where can I get a schematic for this?  They don't have old fashioned picture schematics like Fender used to have, do they?  Could the filter caps be shot on this already??  I tried switching preamp tubes and I didn't luck out.
Offline phsyconoodler
Re: Fender Blues Junior ~Distortion~
« Reply #1 on: August 12, 2013, 09:21:45 pm »
You have two power tubes too you know.Sounds like one is shot.Get a new pair in there and see what happens.If that doesn't do it you have other issues.
stratele52
  • Guest
« Reply #2 on: August 13, 2013, 04:50:02 am »
SCHEMATIC ; There is a Blues Junior III too .
This one is for Blues Junior;  Check also resistor at V3 Phase inverter tube R12 , R14 and other
http://support.fender.com/schematics/guitar_amplifiers/Blues_Junior_schematic.pdf
Offline TerryD
« Reply #3 on: August 13, 2013, 07:36:58 am »
I'll check the power tubes...thanks  and thanks for the schematics.  Terry
stratele52
  • Guest
« Reply #4 on: August 13, 2013, 07:38:40 am »
New tubes ALWAYS need bias check and ajust if needed.
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #5 on: August 13, 2013, 09:54:58 am »
There are 4 versions of the blues junior.
Offline TerryD
« Reply #6 on: August 13, 2013, 10:17:53 am »
How do you tell what version one has? Thanks.
stratele52
  • Guest
« Reply #7 on: August 13, 2013, 10:33:12 am »
You have to look a the circuit in the amp , what is the value of parts , resistor OR  if you have any date on your amp with date of version .
But for your problem no need for now to know wich version you have.
