August 29, 2026, 12:18:14 pm
Hoffman Amps Forum image Author Topic: Since I started over (board layout)  (Read 4063 times)
Offline hesamadman
« on: August 16, 2013, 07:10:54 am »
EDIT: Damn I missed a whole section. Will return this evening!
So Ive been looking at the schematic and studying everything like you guys have said. I made my own layout on photoshop today. I used images from another layout for all my components. Copy and Paste :)
I literally just finished this. I havent got to double check it. Off to work now. But will look at it all day. A couple things that I did and hoping you can tell me if this is ok.
* The 5.6K resistors on pin 5 of the output tubes are connected by a wire to the .022UF caps on top of board. Well instead off having the loose resistors float around on the tubes pins I mounted them on top of board directly to caps. Any issues with this?
* There is a space of blank board over in the preamp section. I did this because I later on want to modify this with a voicing switch where it will switch from different cathode bypass cap values.
Thoughts?
« Last Edit: August 16, 2013, 07:40:59 am by hesamadman »
Offline hesamadman
Re: Since I started over (board layout)
« Reply #1 on: August 16, 2013, 07:39:25 am »
yikes.....found a mistake. missing resistor and 500pf cap wiring wrong
« Reply #2 on: August 16, 2013, 10:43:25 am »
Hey hesa,
I took a minute and pointed out a few things and got rid of your "grid lines"
Keep looking, and keep up the good work  :thumbsup:
