September 15, 2026, 05:21:11 am
Hoffman Amps Forum image Author Topic: Hot Rod Deluxe with -20Vdc measured on the ground  (Read 6254 times)
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« on: September 23, 2013, 09:29:52 am »
anyone with any ideas why this Hot Rod Deluxe would have a measurable -20 at every point that should be ground potential on the main board  :dontknow:
Re: Hot Rod Deluxe with -20Vdc measured on the ground
« Reply #1 on: September 23, 2013, 10:04:32 am »
In reference to what? Chassis? Maybe a high resistance connection to chassis.
Offline Jack1962
« Reply #2 on: September 23, 2013, 10:57:35 am »
sorry I should have been clearer , from any cathode in the amp the cathode side of the cathode resistors a -21vdc can be measured .
« Reply #3 on: September 23, 2013, 12:14:37 pm »
In reference to what??? You have one meter lead on the cathode of a tube but where is the other meter lead? What do you measure if you connect one meter lead directly to one side of a cathode resistor and connect the other lead directly to the other side of that cathode resistor?
Offline Jack1962
« Reply #4 on: September 23, 2013, 12:36:30 pm »
I have one end the black ( or common on most meters ) to the chassis ground , the other lead the red  one to either cathode on the tube or on the cathode side of the resistor I get -21Vdc . from the ground side it depends on which stage of the amp it's between -18 and -21Vdc . What I don't understand is no where (that I see anyway on the schematic or from inspecting the amp is there -21Vdc I see the bias voltage -50Vdc , the voltage for the solid state reverb + and - 16Vdc . I have attached the schematic.
« Last Edit: September 23, 2013, 12:39:00 pm by Jack1962 »
« Reply #5 on: September 23, 2013, 12:50:35 pm »
I'm suspecting a poor ground connection on the pcb. May be caused by a loose connector, broken pcb trace, etc.
What voltage do you measure if you connect one meter lead directly to one side of a cathode resistor and connect the other lead directly to the other side of that cathode resistor?
Turn the amp off and measure resistance from the ground side of a cathode resistor to chassis. Should be zero ohms, but I suspect it is some higher value.
Is the amp sick? What are the symptoms? Do you trust your meter?
Offline Jack1962
« Reply #6 on: September 23, 2013, 02:50:08 pm »
found the problem resistor R63 the 10 ohm resistor that is between the PCB and the chassis (well actually the ground loop on the pots ) was seriously fried. Thanks for the help Sluckey  :guitar1
Offline LooseChange
    • Fix Your Darn Amps
« Reply #7 on: September 24, 2013, 04:16:36 am »
And how did that ^^^^^ happen?
Not sure that solves it... There should be a direct connection from the pc board to ground. Should be either to the right of the input jacks or dead center on the board. (Different models).
Call me Dan
www.fydamps.com
