September 18, 2026, 04:32:16 am
Hoffman Amps Forum image Author Topic: Unused transformer leads  (Read 5468 times)
Offline macula56
  • welcome to the bootyranch
« on: October 25, 2013, 05:24:18 pm »
what do you guys do with your unused PT leads? do you heatshrink them and coil them up somewhere or do you cut them and heatshrink them? thanks, JMac
Re: Unused transformer leads
« Reply #1 on: October 25, 2013, 05:29:06 pm »
I heatshrink them and coil them or tywrap to a bundle or just tuck out of the way. Kinda depends on the particular layout and space available. I don't cut them.
Offline macula56
« Reply #2 on: October 25, 2013, 05:31:24 pm »
i was thinking of tie wrapping them to the leads i am using so as to keep the length and also keep them out of the way. thanks.
Offline macula56
« Reply #3 on: October 25, 2013, 05:32:39 pm »
also, i'm using a 110 volt lamp in this amp. should i wire that before or after the on/off switch? thanks again, Jmac
« Reply #4 on: October 25, 2013, 05:40:19 pm »
If you want the lamp to be controlled by the switch you'll have to wire it after the switch.
Offline quayhog
« Reply #5 on: October 27, 2013, 11:54:11 am »
I usually solder the to an appropriated sized tag strip.   I've seen too many tape wrappings on leads come off.  Sometimes, if its a approptiate unused lead of correct, or  near correct voltage I use the leads for the pilot light.
« Reply #6 on: October 28, 2013, 01:22:15 pm »
IMO wire nuts and/or electrical tape look amateurish inside an electronic chassis.
« Reply #7 on: October 28, 2013, 02:06:14 pm »
Everyone uses whatever is available. Almost everything has been available since 1990.
Offline shoggoth
« Reply #8 on: October 29, 2013, 02:16:24 pm »
I solder the unused lead to an eyelet.  No chance it's going to get loose and wreak havoc then.
