September 16, 2026, 03:58:06 am
Hoffman Amps Forum image Author Topic: O.T. wiring  (Read 6371 times)
Offline chocopower
O.T. wiring
« on: December 10, 2013, 05:09:44 pm »
Hi there!
2 questions:
1.- Any way to hardwire the output in the attached transformer for 8 and 16 ohm?  I mean, 2 jacks or 1 jack with a switch to choose 8 or 16.
2.- That transformer is working already in a old french amp.
     U.L. taps are used and i wanna disconnect them. Any change in secondaries impedance?
thanks in advance!
EDIT: Original attached file deleted due Intelectual Propierty problems.
« Last Edit: December 11, 2013, 08:51:52 pm by chocopower »
David
Re: O.T. wiring
« Reply #1 on: December 11, 2013, 02:21:09 am »
attached schema should work... can it be simplified? maybe?
requires a 4PDT switch.
Offline chocopower
Re: O.T. wiring
« Reply #2 on: December 11, 2013, 04:38:24 pm »
Thanks a lot!!!
I forget to tell that i had to switch the main outputs when i rewire from the original 16 ohm (as i get the amp) to 8 ohm.
The amp have NFB loop and i got a nice oscillation when i rewire to the 8 ohm combination.
Now, the NFB is disable, so:
Should i have any concern about the phase polarity in a amp without NFB?
David
Re: O.T. wiring
« Reply #3 on: December 11, 2013, 08:21:12 pm »
I don't think you are allowed to re-post radiomuseum's images?
Offline chocopower
Re: O.T. wiring
« Reply #4 on: December 11, 2013, 08:43:51 pm »
Hi,
Sorry if i did something inappropriate.
I´m a Radiomuseum member, so i though that i can do it.
If it´s a problem, i delete the file.
David
Offline chocopower
Re: O.T. wiring
« Reply #5 on: December 11, 2013, 08:47:27 pm »
Ok, i have that link from another web.
i delete the original one from Radiomuseum.
Sorry for the inconveniences.
« Last Edit: December 11, 2013, 08:52:46 pm by chocopower »
David
stratele52
  • Guest
Re: O.T. wiring
« Reply #6 on: December 12, 2013, 03:12:18 am »
IMO , the original NFB desing for a 16 ohms may need some different resistor value for 8 ohms. Copy value on other amp using 8 ohms and same Phase Inverter circuit.
Tu dois parler français pour être membre de Radiomuseum ?
Offline chocopower
Re: O.T. wiring
« Reply #7 on: December 12, 2013, 10:09:01 am »
Sorry if i explain it wrong. I dont wanna use NFB at all. My question is about if i could have any problem connecting the OT leads in the "wrong" way. That happen when you do it wrong in a amp with NFB, isnt?
I dont speak French, but i dont need it to have my account and use the Radiomuseum archive.  :dontknow:
David
stratele52
  • Guest
Re: O.T. wiring
« Reply #8 on: December 12, 2013, 12:22:15 pm »
Sometimes yes , if output transformer did not see the speaker , open circuit.
Offline chocopower
Re: O.T. wiring
« Reply #9 on: December 12, 2013, 01:57:21 pm »
ok. i´ll check that to see if DummyLoad schematic can work.
thanks everybody and sorry for the problems i could generate posting the Radiomuseum pic.
David
stratele52
  • Guest
Re: O.T. wiring
« Reply #10 on: December 12, 2013, 03:09:58 pm »
I did not see any problem , you are welcome on the forum and there is not enough picture .
