September 15, 2026, 10:43:46 pm
Hoffman Amps Forum image Author Topic: Why do we call the HT the B rail.  (Read 4317 times)
Offline drgonzonm
« on: December 11, 2013, 02:39:18 pm »
Been on the forum almost two years and didn't see any reference to the above question.
For those afraid to ask, a not so important question. from:  http://www.ampbooks.com/home/amp-technology/battery-amp
In a typical radio built in 1925, the "A" battery supplied filament heat. This is where most power
consumption took place. The battery was physically large and created low voltage and high
current. It was usually a lead-acid battery charged every week by the automobile mechanic
down the street.
The "B" battery, on the other hand, supplied high voltage and low current to the plates and
screens. It lasted a lot longer but was expensive.
Finally the "C" battery set the DC grid voltage. There was never any need for an on-off switch
for this battery either, because grid current was extremely low while operating and non-existent
when the heaters were turned off. Thus the C battery was also left continuously connected.
Through the years it collected dust and cobwebs and eventually died of old age.
So lets not be C batteries
Offline Slimtim
Re: Why do we call the HT the B rail.
« Reply #1 on: December 11, 2013, 03:47:06 pm »
i was wondering myself,thx for sharing with the class.
« Reply #2 on: December 11, 2013, 07:49:15 pm »
A B and C batt connections.
Note multiple B-batt taps-- 130+V for power tube, 90V for driver, 45V for detector and RF stages.
C bias for a type'71 is 30 or 40 volts.
« Last Edit: December 11, 2013, 07:52:09 pm by PRR »
Offline billcreller
  • 1934
« Reply #3 on: December 13, 2013, 03:35:08 pm »
Portable radios of the 30s through early 50s used the A, B, and maybe even a C in the battery pack.
 People I worked with in avionics, referred to "B-plus" some times, and really didn't have a clue why it was called that !!
 As a kid in the 30s & 40s, my dad showed me how to build one & two-tube radios....after I graduated from crystal sets   :icon_biggrin:
 Best, durable B battery was a bunch of D cells soldered in series......
