September 18, 2026, 06:35:35 am
Hoffman Amps Forum image Author Topic: Help with my Mesa MarkIIB  (Read 3438 times)
Offline Marcus
« on: January 09, 2014, 03:27:15 pm »
I just picked up my second Mesa MarkIIB head. I regretted getting rid of my first one. These amps can do anything from shimmering clean to metal. This one I just got has some issues. First off; when I'm on the lead channel the treble doesn't seem to do anything including the push/pull. It works on the clean channel(both functions). This one also has muddy bass and seems a little thin on the bass side. I used to keep the bass on 1 on my old one and I like a lot of bass. My current one doesn't seem to have as much gain as my old one. The tubes are good and I cleaned the pots, switches and jacks. There is no obvious damage inside the amp. It's actually really clean. I checked the schem. and its bone stock. Please help a brutha out!!!!
Offline rzenc
  • TUBES RULE
Re: Help with my Mesa MarkIIB
« Reply #1 on: January 09, 2014, 04:26:30 pm »
its bone stock.
How old is it?
Check power supply e-caps. They dry with age and symptons like you are describing are some of the issues that comes with it.
Best Regards
R.
stratele52
  • Guest
« Reply #2 on: January 09, 2014, 05:20:30 pm »
How did you check tube , by replacement or tube tester ?
Check power supply voltages
Schematic here ;
http://schems.com/manu/mesaboogie/boogie_mkiib.pdf
