September 17, 2026, 06:11:22 am
Hoffman Amps Forum image Author Topic: Here is the recipe for aluminum (chassis) solder with tin  (Read 4666 times)
« on: January 21, 2014, 03:18:07 pm »
I've found this old recipe about how is possible to obtain a metal alloy
to be used to braze welding aluminium with tin
the recipe is for 1 Kg of alloy
ingredients:
. 800gr of pure tin 100%
. 200gr zinc
. a piece of pure aluminium 10mm x 50mm x 1mm
1) Take 200gr of tin and the piece of alluminium and make them melt completely (together)
2) Merge the material just melted with the remaining tin and zinc
3) Cool the alloy slowly and never with water, then form thin rods to be used
This alloy is to be used without acids
Now you can braze welding your own aluminium chassis by yourself
« Last Edit: January 21, 2014, 03:23:14 pm by kagliostro »
