September 15, 2026, 12:46:08 am
Hoffman Amps Forum image Author Topic: where do I find these relays ?  (Read 8388 times)
Offline floyd
« on: January 31, 2014, 10:12:52 am »
I'm looking for these 12V footswitch relays
Re: where do I find these relays ?
« Reply #1 on: January 31, 2014, 10:37:02 am »
Radio Shack, Mouser, or any of the big electronics part houses.
http://www.radioshack.com/product/index.jsp?productId=2062483#
Offline floyd
« Reply #2 on: January 31, 2014, 10:39:47 am »
thanks.. I'm new to switching circuits.
Offline floyd
« Reply #3 on: January 31, 2014, 10:47:36 am »
Sorry , one more question... what is that 5 -pin footswitch jack ?
« Reply #4 on: January 31, 2014, 10:50:18 am »
I would guess it's a 5 pin DIN connector.
« Reply #5 on: January 31, 2014, 11:01:57 am »
Are you considering a scratch build of this amp? If so, you do realize the board is a PCB that you'll have to get from Ceriatone?
Offline floyd
« Reply #6 on: January 31, 2014, 04:30:44 pm »
Which board ? I think this layout reveals where the traces are...
« Last Edit: January 31, 2014, 04:35:38 pm by floyd »
« Reply #7 on: January 31, 2014, 04:58:23 pm »
There is a great deal of information here about using Doug's relays on builds like Dumblish clones.  You might want to consider this as an alternative given Doug carries everything to make this successful.
http://www.el34world.com/Forum/index.php?topic=14348.0
And Doug carries relay boards, relay sockets, relays, and the power supply board for the switching also:
http://www.hoffmanamps.com/MyStore/perlshop.cgi?action=template&thispage=Lamps&ORDER_ID=107140777
with respect, Tubenit
Offline floyd
« Reply #8 on: January 31, 2014, 05:06:23 pm »
  Yes I agree with you ! But this being the first time I'll be dealing with relays , Ceriatones' relay circuit is very easy for me,  at this point.
« Reply #9 on: January 31, 2014, 09:42:06 pm »
Good, but have you taken a look at the links posted by Tubenit ?
« Reply #10 on: January 31, 2014, 11:46:08 pm »
Hmm, that layout looks nothing like the layout in your original post.
Offline floyd
« Reply #11 on: February 01, 2014, 07:31:44 am »
The 1st layout is kind of a  "lite "version of the Overtone Special.
Offline floyd
« Reply #12 on: February 01, 2014, 07:37:36 am »
Yes.. a very helpful link.
« Reply #13 on: February 01, 2014, 08:26:38 am »
Since you are not interested in a particular amp, you may want to consider using 5 volt relays. They operate exactly the same as the 12 volt relays, but the power supply is quite a bit simpler. And Doug carries the 5 volt relays, relay boards and power supply board.
