September 18, 2026, 05:35:18 am
Hoffman Amps Forum image Author Topic: Old Geloso Mic Mixer conversion to Line Mixer - How ??  (Read 8186 times)
« on: February 10, 2014, 10:56:26 am »
This attached is the schematic of an old transistor Mic Mixer by Geloso
is possible to convert it in Line Mixer and how ?
Re: Old Geloso Mic Mixer conversion to Line Mixer - How ??
« Reply #1 on: February 11, 2014, 05:19:59 pm »
Thanks Drgonzonm
I was asking about something to do as to preserve the original circuit
I'm asking about a mod as to be able to adequate the existing circuit to higher level signal (if doable)
Thanks Again
« Reply #2 on: February 11, 2014, 09:37:21 pm »
Clip one end of the 200uFd emitter caps.
Preamp gain drops from almost-100 to almost-1.
However drgonzonm has a point. A line level mixer often does not need any preamp, and going from input jack to mix-pot may be cleaner. Since the mix-bus pots are "inverted" (input at wiper, bus on the top), you need 5K or 10K between input and pot wiper.
« Last Edit: February 11, 2014, 09:39:49 pm by PRR »
« Reply #3 on: February 12, 2014, 02:42:02 am »
Many thanks PRR
this 5-10k resistor is in place of the AC107 circuit, is that correct ?
« Reply #4 on: February 13, 2014, 12:25:35 am »
« Reply #5 on: February 13, 2014, 08:17:01 am »
PRR as always you are very kind
Thanks Again
