September 15, 2026, 07:53:01 am
Hoffman Amps Forum image Author Topic: Weak and crackling sound  (Read 4069 times)
Offline Leevi
    • Rikstone
« on: February 10, 2014, 11:45:30 pm »
The sound is is very weak and it's crackling. I measured the voltages on PI pins 1 and 6.
1: 166v
6: 250v
I'm just wondering this big difference but have not found any good reason for it.
Heaters have been cheked and I have tried with another tube.
http://www.kolumbus.fi/~y635749/RikstoneAmps/PowerAmpC15b.pdf
The amp is very simple, one EF86 as a preamp.
Leevi
stratele52
  • Guest
Re: Weak and crackling sound
« Reply #1 on: February 11, 2014, 02:36:53 am »
Check all Power Supply voltages
« Reply #2 on: February 11, 2014, 08:09:06 am »
"Crackling" can sometimes be caused by plate resistors, especially when using carbon comp resistors.
Weak? This is just a power amp and requires about 1 Vrms to drive to full power. You're not trying to plug your guitar straight into point C1 are you?
Offline Leevi
    • Rikstone
« Reply #3 on: February 11, 2014, 08:35:34 am »
I just added the schematic of the power amp. There is EF86 + 6 pos cap. switch + volume
before PI. I have checked the signal level after preamp and it's OK.
/Leevi
« Last Edit: February 11, 2014, 08:50:12 am by Leevi »
Offline Leevi
    • Rikstone
« Reply #4 on: February 11, 2014, 12:46:09 pm »
There was cap missing between volume and PI input.
Now at least the plate voltages are in balance but there are still some
oscillation problems I have to fix by changing the wiring.
/Leevi
