September 08, 2026, 04:21:54 pm
Hoffman Amps Forum image Author Topic: Transformer for Tubenit's one tube reverb?  (Read 4826 times)
Offline Stankfut
« on: February 11, 2014, 01:44:13 pm »
Trying to find which transformer to use in a one tube reverb. I know the fender units are designed to use a paralleled 12AT7 to drive the transformer, so a single tube would need twice the primary impedance, right? I've looked in the archives and not having much luck finding the information.
Thanks!
Re: Transformer for Tubenit's one tube reverb?
« Reply #1 on: February 11, 2014, 01:59:56 pm »
Impedance is not critical; the whole idea is a "small" reverb for non-Surf music. And as you say you don't get a choice. Use the part sold for 2*12AT7 duty.
« Reply #2 on: February 11, 2014, 02:00:58 pm »
I used Hoffman's reverb trannie and tank.
from ARCHIVES 1st post on the one tube reverb:
This uses the "Fender" type replacement reverb transformer and tank that Hoffman sells. Same one you'd use for a Princeton Reverb.
« Last Edit: February 11, 2014, 02:21:19 pm by tubenit »
Offline Stankfut
« Reply #3 on: February 11, 2014, 04:03:37 pm »
Thanks PRR and Tubenit! I missed that post, will search again tonight (must be user malfunction). I didn't want to make assumptions about the impedance, so I figured it was better to ask :icon_biggrin:
Offline Stankfut
« Reply #4 on: February 11, 2014, 04:23:35 pm »
Ah, I see the problem. I used the search function instead if going into the archive area.....d'oh! Lesson learned!
Offline pullshocks
« Reply #5 on: February 12, 2014, 01:11:04 am »
I have a SE OT supposedly pulled from an amp running a 6L6 output tube (5000:8 ?)  would that work?
