September 17, 2026, 09:22:48 am
Hoffman Amps Forum image Author Topic: 5e3 weird scratchy pot problem...  (Read 10681 times)
Offline Phil_Tre
« on: February 16, 2014, 06:40:29 pm »
Ok, it's a weird one:
I have build a 5e3 about a year ago, working perfectly, it's the Tube Depot kit.
Problem is, when I turn the bright ch volume pot, I can hear a scratchy noise,
like a scratchy pot, but only from 1 to 1 3/4. Also, if there is no signal from the
guitar, than no noise at all. Only when turning the pot from 1 to 2 and plucking
strings.
It's not the pot because I change it to try, I measure no dc voltage at the input
jack (from the guitar cable). Not the tubes, have test every socket with new tubes
multiple times. So what could it be ? Bad coupling cap ? I'm lost...
Thanks for your help !
Philippe
Please, no comments on my Blackface style filament in a Tweedish amp  :icon_biggrin:
The circuit is almost stock, except it sports the Deluxe Reverb transfos.
Re: 5e3 weird scratchy pot problem...
« Reply #1 on: February 17, 2014, 12:28:33 am »
> I measure no dc voltage at the input jack
But the scratch is at the pot. *Carefully* check for DC at all three pot terminals.
Most likely cause is a leaky cap from plate to pot.
Another possibility is leaky circuit-board or damp flux on the board. (Or dead vermin, but that's obviously not the case in your clean build.)
Another strange one is a leaky *grid* on the *next* tube. Easily checked.
stratele52
  • Guest
« Reply #2 on: February 17, 2014, 06:53:52 am »
+1 PRR ,a leaky cap
Online sluckey
« Reply #3 on: February 17, 2014, 07:12:38 am »
Problem is, when I turn the bright ch volume pot, I can hear a scratchy noise...
Also, if there is no signal from the guitar, than no noise at all.
Only when turning the pot from 1 to 2 and plucking strings.
So, it's only scratchy when you turn the pot while plucking. Otherwise, it's fine. How often do you pluck 'n turn at the same time?
« Reply #4 on: February 17, 2014, 07:59:53 am »
       :laugh:
« Reply #5 on: February 17, 2014, 09:50:24 am »
... when I turn the bright ch volume pot, I can hear a scratchy noise, like a scratchy pot, but only from 1 to 1 3/4. Also, if there is no signal from the guitar, than no noise at all. Only when turning the pot from 1 to 2 and plucking strings.
I'm gonna vote for a bad pot, as I'd think d.c. leakage would make it scratchy over the full travel.
Play louder than volume on 1-2. Don't play while turning the pot from 1-2.
Or replace the pot.
stratele52
  • Guest
« Reply #6 on: February 17, 2014, 10:48:29 am »
Or replace the pot.
He write ; "It's not the pot because I change it to try," :dontknow:
Offline Phil_Tre
« Reply #7 on: February 17, 2014, 11:28:21 am »
Ok guys, I will check again for DC leak...
It's not a big problem, just annoying when I try
to adjust for low volume... 5e3 volume pots are
very finicky: from 1 to 3 = whisper to scream !!
Thanks !
Phil.
« Reply #8 on: February 17, 2014, 12:46:59 pm »
I know, and at first I thought it must be leakage. But what causes a pot to only be scatchy over a very short portion of its travel?
It's not a big problem, just annoying when I try to adjust for low volume... 5e3 volume pots are very finicky: from 1 to 3 = whisper to scream !!
You might want a smaller amp; I'd suggest a 5F2 Princeton, as it is basically a Champ but has a tone control just like the 5E3.
stratele52
  • Guest
« Reply #9 on: February 17, 2014, 01:31:54 pm »
Thanks !
Phil.
You probably have a " B " pot , linear and you need a "A" pot , logarytmic or audio pot . "B" pot  work like you are in full power in first quarter turn .
stratele52
  • Guest
« Reply #10 on: February 17, 2014, 01:33:33 pm »
I see that before and it was a leaky cap
Offline Phil_Tre
« Reply #11 on: February 17, 2014, 04:10:09 pm »
Thanks !
Phil.
No, those are audio pots... That's what you get using a 12AX7 in v1 in a 5e3 instead of a 12AY7...
Offline Phil_Tre
« Reply #12 on: February 17, 2014, 04:41:43 pm »
Yes, I will probably build a Tweed Princeton for my next amp. I already built a Tweed Vibrolux and a Tweed Deluxe so maybe a
Black Face next time as I wanted a clean platform for effects, maybe a 1/2 power Twin  :lipsrsealed:
stratele52
  • Guest
« Reply #13 on: February 17, 2014, 04:49:52 pm »
Offline Phil_Tre
« Reply #14 on: February 17, 2014, 06:26:44 pm »
Yes it is a Audio pot . Schematic here
https://d1sjrnpi226dnf.cloudfront.net/spree/attached_files/tweeddeluxe_schematic.pdf?1382030448
language barrier here, sorry... Yes, Audio pots were installed in my amp. It's just that when using
a 12AX7 in preamp in a 5e3, you got a lot of gain as soon as you turn the pots... It's the nature
of the beast. It's not as bad with the specified 12AY7...
stratele52
  • Guest
« Reply #15 on: February 18, 2014, 03:13:39 am »
+1
