September 15, 2026, 08:33:41 am
Hoffman Amps Forum image Author Topic: Effects loop in single channel AB763 deluxe style amp  (Read 5155 times)
Offline Toxophilite
« on: February 26, 2014, 09:44:45 pm »
Hello
I'm wondering where I would insert an effects loop in a single channel AB763 style deluxe amp
I'm thinking right before the PI. Is that right?
And what would be the best way to go about it?
THanks!
Re: Effects loop in single channel AB763 deluxe style amp
« Reply #1 on: February 26, 2014, 10:02:41 pm »
Look at the schematic on the bottom of this page for a simple passive loop.
http://home.comcast.net/~seluckey/amps/november/november.htm
« Reply #2 on: February 27, 2014, 02:24:59 am »
The passive FXLoop is the easiest solution and has a low impact on the existing amp
if you need an active FXLoop you can consider also a stand alone unit like the Dubleator
for a layout you can use the Ceriatone C-Lator version
and if you prefer SS the Klein-ulator
« Reply #3 on: February 27, 2014, 05:01:55 am »
Simple passive effects is very easy to do and works well.
IF you want an active effects loop that is on board, then you can consider this from ARCHIVES:
http://www.el34world.com/Forum/index.php?topic=10208.0
Offline Toxophilite
« Reply #4 on: February 27, 2014, 04:33:00 pm »
Most Excellent and thank you all!
I have a Keil spring reverb unit pulled from an early 60s organ
I alligator clipped it in just before the PI and it sounds lovely..Huzzah Reverb!
Now I'll have a S.lucky Ab763lite frankentremedeluxeSSreverb!
I believe an acronym might be in order
Now I'm kicking myself for selling a tube organ mate last year!
Still this SS keil unit is very nice sounding
A few female RCA jacks installed and some tweaking of the control pot and it should do the trick nicely
