September 19, 2026, 07:10:00 pm
Hoffman Amps Forum image Author Topic: Schematic of Paul C Mod Question  (Read 9588 times)
« on: March 05, 2014, 05:43:40 am »
In this comparison schematic, what would be the difference instead of adding the 2m2 resistor from removing the 1meg and adding 3m3 resistor.
Re: Schematic of Paul C Mod Question
« Reply #1 on: March 05, 2014, 05:53:50 am »
I'm not quite sure what you are asking. The original circuit is bootstrap biased. Paul C is fixed bias. A pic of what you ask would probably help.
« Reply #2 on: March 05, 2014, 07:21:25 am »
Sorry, this should clear it up.
« Reply #3 on: March 05, 2014, 07:36:18 am »
Look at those 2 resistors as being in parallel and you'll come up with a combined value of about 680K.
It might have just been easier for him to leave the 1M there and add the 2.2M  :dontknow:
Or he just didn't have any 680Ks in stock.....I don't.   :icon_biggrin:
« Reply #4 on: March 05, 2014, 07:59:23 am »
Yes, I see it is 687.5k.  The value is not what I was thinking, I was wondering if there is a specific reason for having the parallel.  Since I use a 4m7 instead of the 2m2 in princetons that is 825k.
I tried a single 1 meg linear pot last night in place of both resistors and the results were like a master, but I do not know if this would cause a problem.
I have been messing around with split load a lot lately and am really liking the results.
« Reply #5 on: March 05, 2014, 08:11:14 am »
No no no. The resistors are not in parallel. The bottom end of the 2.2M connects to B+. This creates a voltage divider between B+ and ground that places a large positive voltage on the grid of the tube. IOW fixed bias.
You cannot remove the 1M. Doing so will break the fixed bias voltage divider and put full B+ on the grid!
« Reply #6 on: March 05, 2014, 08:33:10 am »
[/quote]
Would it create a problem to use a pot instead of the 2m2 resistor?  I am attempting to find an alternative place for a MV, but since I have never seen this done it probably will not work.
« Reply #7 on: March 05, 2014, 08:36:53 am »
WOW!
Sorry guys....that's what I get for posting pre-coffee...  :huh:
I was looking at the 2.2M as going to ground....(just used to seeing schematics that way,,,so the snippet got me)
 :BangHead:
« Reply #8 on: March 05, 2014, 08:49:56 am »
WOW!
 :BangHead:
No biggie, I have done this mod at least 50 times and I know they are not in parallel.  What I was getting at is I put a pot on last night in-place of the 4m7 I have in a build and it sounded great as a Master Volume.  I am just wanting to know what I am going to fry as my ideas usually come with drawbacks.
« Reply #9 on: March 05, 2014, 09:27:45 am »
Yes. You will also be messing with the fixed bias on the tube.
If you want to use a pre PI MV and the Paul C mod, I suggest you simply put a cap and standard wired volume control BEFORE that .02 coupling cap.
If you want to add a pre PI MV to the original you can use this circuit. (Sure seems like this discussion was just on the forum in the past few weeks. Not sure, though.)
« Reply #10 on: March 05, 2014, 09:49:37 am »
It was discussed recently, that is why I am messing with it.  The amp is not a 5E3, but does have a split load in the same configuration as an AA1164, but with a PT and OT designed for a 50 watt Bassman.
The cap and volume sounds like the deal. I actually wired up a Dual pot master but it does not sound good at all.
I sort of stole the preamp from a plexi and the power section is a beefed up Princeton.  Kinda cool sounding and is running KT66's.
Thanks for the input, I will give it a try tonight.
