September 17, 2026, 05:45:27 am
Hoffman Amps Forum image Author Topic: Recovered transformer 0-310v (200-250mA ???) - 7v 2A - Any idea ???  (Read 4252 times)
From a small Tube Linear Amplifier for RF I recovered a transformer (about 100-120W) with 0-310v and 7v 2A
I consider the 7v as a 6.3v winding, if it diden't drop by himself during function, a resistor will do the job
in the original schematic the 0-310v winding was used with a voltage doubler, but considering to use it with
a full bridge I think I'll obtain about ~430v for tube plates (I think that there are ~200mA disposable)
Any idea about the reuse of this transformer ?
Re: Recovered transformer 0-310v (200-250mA ???) - 7v 2A - Any idea ???
« Reply #1 on: March 16, 2014, 03:03:23 pm »
Heavy duty B+ but light weight filaments. Probably perfect for a one or two tube RF linear amp.     :icon_biggrin:
« Reply #2 on: March 16, 2014, 04:56:18 pm »
:icon_biggrin: Yes :icon_biggrin:
but something around 18W audio with which tubes ??
Ciao Steve  :smiley:
« Reply #3 on: March 17, 2014, 09:39:50 am »
You may consider Mark Huss's Plexi 6V6. Three 12AX7s and two 6V6s. Filament current is 1.8A and the 6V6s can take the B+.
     http://mhuss.com/Plexi6V6/index.html
« Reply #4 on: March 17, 2014, 04:48:42 pm »
443v at node A !
That seems really perfect  :thumbsup:
Grazie Steve
« Reply #5 on: March 19, 2014, 12:03:45 pm »
My plan failed
I received the transformer today
and it hasn't the specs I told
I referred the 310v (with doubler) and 7v to a model of Linear amplifier that used 1 x 6KD6 tube
but the donor linear of the transformer uses the same 1 x 6KD6 tube
but a 500v (no doubler) winding instead of 310v
So I think this thing will be usable only if I rewind it  :embarrassed:
« Last Edit: March 19, 2014, 12:16:33 pm by kagliostro »
« Reply #6 on: March 19, 2014, 03:54:40 pm »
Thanks for the idea
solution may be also that way
