September 17, 2026, 11:31:47 pm
Hoffman Amps Forum image Author Topic: Silverface Super Reverb troubles  (Read 7281 times)
Offline TubeGeek
    • Glacier Amps
« on: March 29, 2014, 01:43:50 pm »
I have a mint silverface super reverb in for service and I can't even remove the chassis from the cabinet. :cussing:
What's happening is there is a steel or aluminum plate that is stapled to the inside of the top of the cabinet and that has come loose.  If shine a flashlight to see what is preventing the chassis from sliding out as normal, I can see the staples have actually come loose and are preventing the chassis from sliding out.  It looks like I am not the only one who has tried to remove the chassis before as the power transformer bolts are loose, I am assuming from someone else trying to pry it out.  To top it off, it also looks like the shield plate has been bent and is also blocking the chassis from coming out. :BangHead:
I have tried everything with no success.
If I could remove the speaker baffle, then I may be in luck but the baffle is glued in. :cussing:
Has anyone run into this problem before?
How the heck am I supposed to remove the chassis now?  :w2: :help: :dontknow:
Any ideas?
Re: Silverface Super Reverb troubles
« Reply #1 on: March 29, 2014, 01:57:48 pm »
I would remove the speakers to lighten the load. Remove the chassis straps, screws, and nuts, and tubes. Then turn the cab upside down. Use thin putty knives (not the plastic ones) to slip between the chassis and the shield plate. You may need several different widths on the putty knives.  Try to flatten/smooth out the bent plate. Then just keep wiggling, pushing, pulling, etc., until; it begins to move. You will need a lot of patience. Don't drink beer while doing this! Good luck.
Offline TubeGeek
    • Glacier Amps
« Reply #2 on: March 29, 2014, 02:11:34 pm »
Patience indeed.
Tequila might help :l2:
stratele52
  • Guest
« Reply #3 on: March 29, 2014, 02:54:43 pm »
I just had same problems with Silver face Super Twin Reverb !!!!   Patience...... patience. I takes me at least 15 minutes if not 30 .........
Mine was very very heavy, 180 watts amp .
Offline TubeGeek
    • Glacier Amps
« Reply #4 on: March 29, 2014, 03:03:58 pm »
Jeez this is the third time I have tried over the past couple of days.  I'm probably an hour in already of time and I can't even get the chassis to budge.  It is really stuck on that shielding plate.
stratele52
  • Guest
« Reply #5 on: March 29, 2014, 03:05:11 pm »
 :cussing:
stratele52
  • Guest
« Reply #6 on: March 29, 2014, 03:35:30 pm »
Try a very long steel spatula, use two or more . IMO  there are avalaible 10 to 12 inches long (?) cheap at dollar tree ?
http://www.ebay.com/itm/FLINT-USA-Arrowhead-Logo-Stainless-Icing-Spatula-Spreader-Knife-NICE-/310912193708
Offline TubeGeek
    • Glacier Amps
« Reply #7 on: March 29, 2014, 07:38:05 pm »
Could possibly work, thanks for the tip. Dollar tree here I come...
« Reply #8 on: March 30, 2014, 03:22:54 pm »
This is simple and it happens all the time.
I used to just slide in a very thin metal paint scraper and push the metal shield back up
Just go side to side and pull back
Offline LooseChange
    • Fix Your Darn Amps
« Reply #9 on: March 30, 2014, 04:57:53 pm »
Doug beat me to it. I do the exact same thing.
You want to get the scraper under the metal sheet to push it up out of the way.
Call me Dan
www.fydamps.com
stratele52
  • Guest
« Reply #10 on: March 31, 2014, 04:09:03 am »
And I beat Doug a day before  :laugh:
Offline LooseChange
« Reply #11 on: March 31, 2014, 04:15:51 am »
Nope... You said spatula and we said scraper. :)
Call me Dan
www.fydamps.com
stratele52
  • Guest
« Reply #12 on: March 31, 2014, 05:04:25 am »
Most of people don't know or don't think to spatula . Short spatula is like a scrapper
For this issue it do the same job but ( long ) spatula is longer than scraper and may work better .
Scraper could be too short . If you have to buy something you'd better go with spatula.
You can use a piece of steel , aluminium , copper too . All you can find in hardware or hobby shop .
Al those are not scraper :laugh:
