September 15, 2026, 12:23:29 am
Hoffman Amps Forum image Author Topic: Jschem problem on Windows 7 64bit - How to solve ??  (Read 12145 times)
« on: April 18, 2014, 02:52:48 am »
I was constricted to update my PC so now I run under Windows 7 64bit
I must say I'm satisfied of the new OS but I encounter a problem
I'm no more able to use Jschem, if I start the program I receive a warning
telling me that I've no Java installed on my PC on the contrary I've the last Java disposable installed
Please, can someone give me help ?
EDIT: I solved the problem, instead to download and use the Windows version of Jschem (.exe), I downloaded the Any other OS version (.jar), this last has no problem with my Windows 7 64bit + Java 7.55 64bit :thumbsup:
« Last Edit: April 18, 2014, 03:25:22 am by kagliostro »
Re: Jschem problem on Windows 7 64bit - How to solve ??
« Reply #1 on: April 18, 2014, 05:24:02 pm »
I don't install the 64 bit java on my 64 bit machines
I install the 32 bit versions
Which Java do you have installed?
« Reply #2 on: April 23, 2014, 03:26:52 am »
Ciao Doug
I've the 64bit version of Java
« Reply #3 on: April 23, 2014, 05:30:18 am »
You can install the 32 bit version instead
That's what I do on my 64 bit machines and jschem works
Try uninstalling the 64 bit version and get the 32 bit version here on this page and see if that works
This page has both versions
http://www.java.com/en/download/manual.jsp
« Reply #4 on: April 23, 2014, 06:09:11 am »
Thanks, I'll give a try
« Reply #5 on: April 23, 2014, 09:23:27 am »
Hi Doug
I was on the page you linked and I've read this
We have detected you may be viewing this page in a 32-bit browser. If you use 32-bit and 64-bit browsers interchangeably, you will need to install both 32-bit and 64-bit Java in order to have the Java plug-in for both browsers. »
As I use both browsers, I installed the 32bit version and didn't deleted the 64bit version that I had previously installed
Now with both versions installed all is fine and Jschem for windows opens regularly
Many Many Thanks
« Reply #6 on: April 23, 2014, 10:01:19 am »
Cool
I don't use the 64 bit browser
I forgot that windows comes with both versions
« Reply #7 on: April 23, 2014, 10:23:13 am »
I use both versions of Opera  :icon_biggrin:
the old 32bit Opera 12.16 (that I prefer for the functions it has)
and
the new 64bit Opera 20.0 based on Chrome core (if I encounter particular difficulties)
I've also IE 11 that comes with windows, but I really don't know if it is 32 or 64 bit  :laugh:
Grazie Ancora
« Reply #8 on: April 23, 2014, 10:58:50 am »
ok, I was assuming you were using IE11
Windows 7 comes with 32 bit and 64 bit versions of IE11
probably windows 8 also
« Reply #9 on: April 23, 2014, 11:21:35 am »
 Thanks for the info :thumbsup:
