September 14, 2026, 09:15:02 am
Hoffman Amps Forum image Author Topic: Converting to adj. -bias on an Ampeg B-25-B  (Read 9586 times)
« on: May 13, 2014, 08:58:00 am »
The bass player from church asked me to fix his Ampeg B-25-B. Needs new tubes/filter caps.
I'm thinking making R-38 about 1/2 it's value, ~22K to 26K and standing it on the 50K trim pot Doug sells. With the pots wiper centered that should set the -bias around where it was set from the factory and give a little range up/down for new tubes.
Yes?
 http://el34world.com/charts/Schematics/files/ampeg/Ampeg_b25b.pdf
            Thanks,   Brad    :icon_biggrin:
« Last Edit: May 13, 2014, 09:14:11 am by Willabe »
Re: Converting to adj. -bias on an Ampeg B-25-B
« Reply #1 on: May 13, 2014, 03:14:02 pm »
Yep, that sounds reasonable.
« Reply #2 on: May 13, 2014, 03:35:35 pm »
Ok, thanks HBP.
If I don't get enough -dcv I guess I'll try making the 100K/2w series R (R 40) smaller.
stratele52
  • Guest
« Reply #3 on: May 13, 2014, 05:45:19 pm »
Ok, thanks HBP.
Start with higher R38 and R39 , if not enough - DC ,  try R40 smaller
« Reply #4 on: May 13, 2014, 05:47:43 pm »
Or R39 bigger. It creates a voltage divider for the raw a.c. before it hits the rectifier diode.
Yes, it uses more parts than Fender's setup; I think the intent is to be certain to have the lowest a.c. output impedance possible from the bias supply (the bias feed resistors see only a bias cap to ground) but the highest d.c. impedance (the bias feed resistors see only a bias cap to ground).
Yeah, what he said!
« Reply #5 on: May 13, 2014, 06:17:32 pm »
OK guys, I get it, thank you.
Yeah, I figured that they wanted to make sure the -bais was stable because of the 500dcv plate and 490dcv screen.
             Brad     :icon_biggrin:
« Last Edit: May 13, 2014, 06:21:20 pm by Willabe »
« Reply #6 on: May 13, 2014, 10:44:46 pm »
Would you go deeper into this please? I think your saying the 'bias feed R's are the series R's?
I see they put a voltage divider before the diode to knock down the B+ fed to the diode, then they have a pie filter.
So having the 2nd filter cap as the last thing the -bias feeds the 220K grid leaks is what makes it low Z?
                  Brad      :think1:
« Reply #7 on: May 13, 2014, 11:49:44 pm »
After looking at the schematics for the Princeton Reverb and for Marshall amps that tap bias from the high voltage winding, I may have to retract my statement.
When I said "bias feed" I mean the grid leaks for the output tubes, which feed bias voltage to the grids. Looking at the Fender and Marshall schematics, they have a resistor to ground from the junction of those grid leaks, but there is a cap to ground as well. The cap would still be effective at holding that junction at a.c. ground even if there is a resistor present.
I think I was looking for an explanation on why Ampeg used so many more parts than they needed to do the job. I guess now I don't have a good answer for that.
So it looks like the Ampeg circuit could have been simplified; either way, I think you know how to tinker it to get the needed range of bias voltage.
stratele52
  • Guest
« Reply #8 on: May 14, 2014, 03:53:35 am »
Yeah, what he said!
I don't see where he is talking about R 39
« Reply #9 on: May 14, 2014, 06:52:03 am »
Yeah, what he said!
My post was speakeing to Willabe; so when I said, "What he said," I meant what you (Stratele) said. You posted while I was still typing my reply.
stratele52
  • Guest
« Reply #10 on: May 14, 2014, 07:03:11 am »
Ok I understand ,Thank's
We should begin post by
Hi HotBluePlate ,
( answer here )
Offline ernie_jr
  • gimme a banana
« Reply #11 on: May 15, 2014, 06:33:09 am »
Another option that I have used on a scratch built b 25 is after R40 (the 100K off the p/t) build a bias circuit that SUNN uses in their 200s, etc. Sunns also used about 500 volts on the plates and this circuit gives a fairly wide range of adjustment.
Good luck,
Ernie
« Reply #12 on: May 15, 2014, 07:27:36 am »
Thanks Ernie, I'll look at that.
            Brad    :icon_biggrin:
