September 14, 2026, 02:27:11 pm
Hoffman Amps Forum image Author Topic: Two channel amp with EF86´s. Mixing resistors size.  (Read 3882 times)
Offline chocopower
« on: May 13, 2014, 09:06:23 am »
Hi there!
In the attached schematic, do you think i picked the right value for mixing resistors?
After the Send/Return jacks i have a 1M resistor to ground. I know that with both volume pots in both channels just before the 12ax7 there is no need for it, but if i use the amp as a tube "power amp", that means, connecting the signal to the "return" jack, i will need a grid leak resistor. If some one have any idea to make it better without loosing signal due to the voltage divider, i will thank you a lot.
thanks!
David
Re: Two channel amp with EF86´s. Mixing resistors size.
« Reply #1 on: May 13, 2014, 09:18:32 am »
If you make the mixing resistors 220K you will have less signal loss due to the voltage divider with the 1M. Isolation between channels would still be good too.
Offline chocopower
« Reply #2 on: May 13, 2014, 09:44:30 am »
Thanks!  I´ll give a try!
David
