September 16, 2026, 11:08:22 am
Hoffman Amps Forum image Author Topic: 220v Power Transformer with 235v wall voltage.  (Read 4581 times)
Offline chocopower
« on: June 04, 2014, 12:55:25 pm »
I´m working in a old 60´s amp with a 220v designed P.T.
Since here in Spain we have now 235-240v  and the amp use a GZ34 as rectifier, Will be a good idea use a different rectifier to drop voltages in whole amp ?
This way DC  voltage will be close to original ones.
David
Re: 220v Power Transformer with 235v wall voltage.
« Reply #1 on: June 04, 2014, 01:35:57 pm »
A 5Y3 in place of your GZ34 should drop your B+ 20-30 volts....you may need to drop it a little more.
« Reply #2 on: June 04, 2014, 02:26:22 pm »
Your heater voltages are still high.
It may be time to study step-down transformers for all your older gear.
Offline chocopower
« Reply #3 on: June 04, 2014, 04:10:59 pm »
Thanks all!  i´ll check filament voltages and make a decision.
David
Offline printer2
« Reply #4 on: June 04, 2014, 09:28:29 pm »
What I did once is put a resistor on the input side of the transformer. Dropped the voltage until my heater voltage was correct.
