September 16, 2026, 12:13:38 pm
Hoffman Amps Forum image Author Topic: What are theses pcb leds for?  (Read 6032 times)
Offline frank57
« on: June 13, 2014, 02:45:15 pm »
I have this Hiwatt solidstate the Bulldog 30r.
it was working fine for quite awhile.
It sounds like the volume is a bit low on the clean channel.
Are the pcb Leds2 and 3 to indicate which channel is on?
At the moment I don't see either led on.
i drew up the board before but I also have attached the schematic.
It's had some issues in the past this amp with volume levels not staying consistent.
Other thing was: how would I wire the jack if I wanted it off the pcb?
the input jack section was cut by a tech to stop a radioo problem.I didn't indicate it
« Last Edit: June 13, 2014, 02:53:01 pm by frank57 »
