September 16, 2026, 05:22:08 am
Hoffman Amps Forum image Author Topic: Built a stout reverb and want some tweaks to experiment with.  (Read 3879 times)
Offline goldstache
The stout reverb is rocking little amp.
Just a couple of questions:
1. It seems as though my mix is wired backwards
CCW verb
CW dry
As per schematic, is this how everyone else has it?
Also it's a nice light verb, wondering if I can get her a little more wet :icon_biggrin:
2: any tone control options recommended?
Thanks!
Re: Built a stout reverb and want some tweaks to experiment with.
« Reply #1 on: July 10, 2014, 01:09:07 pm »
CCW verb
CW dry
You can reverse the connections to the outside lugs of the mix pot if you prefer to have CCW=dry.
Replace the .68µF cathode bypass caps on V1-3 and V3-8 with 22µF caps to increase the gain of the reverb circuit. Might get you enough verb. Also, increasing the value of the coupling caps on V1-1 and V3-6 will give you a fuller sounding verb and maybe a little stronger verb too.
Offline goldstache
« Reply #2 on: July 10, 2014, 04:27:55 pm »
Well I swapped the wires for the mix pot.
Interestingly the tone control now works till about 7 at which point it starts to roll off highs?????
I also get a loud DC on pot sounding crackle when mix is full CW (max wet)????
I have no DC on any of the pots legs.  Hmmm
Funky pot maybe.
Also still trying to get a lilttle more EQ flexibility.
Any other thoughts?
