September 08, 2026, 04:41:55 pm
Hoffman Amps Forum image Author Topic: Octave down effect with tubes  (Read 18441 times)
Offline Lauri
« on: August 05, 2014, 10:24:37 am »
I was trying to find out if anyone has ever made a octave down effect using tubes, but after searching the internets for hours I didn't find anything useful. So here's a circuit I put together and it works pretty well.
Schematic:
http://www.kolumbus.fi/~kp5188/musiikki/octaver.png
First double triode is just a regular voltage amplifier and low pass filter. Second one converts the signal to square wave and the third one is a flip-flop circuit.
Sound sample:
http://www.kolumbus.fi/~kp5188/musiikki/octaver.flac
Re: Octave down effect with tubes
« Reply #1 on: August 05, 2014, 10:29:42 am »
Oh yeah!! I made something like that (using tubes) when I was a kid. And a ring modulator, too. Trouble is...the sophistication and response time you can get with modern op-amps will probably devastate tube performance by any measure. Cool, though!!
« Reply #2 on: August 05, 2014, 09:08:09 pm »
Very clever.
« Reply #3 on: August 10, 2014, 09:45:47 am »
Cool circuit!
Sounds cool too
« Reply #4 on: August 11, 2014, 02:56:00 am »
Is this made as a stand-alone effect unit? I've did a bunch of R&D work on an old effects circuit that gives a bit of octave down called the Harmonic Percolator but it's much more subtle and actually more of a side effect of the circuit, not it's main purpose.
« Reply #5 on: August 11, 2014, 09:56:06 am »
Awesome Lauri. Thanks for sharing.
Offline Lauri
« Reply #6 on: August 12, 2014, 10:53:48 am »
Right now it's made on a test chassis. At some point I will either make an amp that will have it integrated in it or a stand alone unit.
« Reply #7 on: August 25, 2014, 03:23:36 am »
Ciao Lauri
intriguing circuit  :smiley:
Which is the value of R1 ? Is it the "standard" 1M resistor ?
Offline Lauri
« Reply #8 on: August 27, 2014, 10:10:09 am »
Yes it can be 1M or whatever you want the input resistance to be.
« Reply #9 on: August 27, 2014, 10:33:45 am »
Thanks Lauri
Offline Lauri
« Reply #10 on: September 02, 2014, 07:27:50 am »
Here's the schematic and a picture of a stand alone octaver unit I built.
http://www.kolumbus.fi/~kp5188/musiikki/octaversch.png
http://www.kolumbus.fi/~kp5188/musiikki/octaverpic.png
« Reply #11 on: September 02, 2014, 07:50:56 am »
Thanks for sharing
I've a question for you
I see a pair of CF (U1A = ECC83 - U2A = ECC82) acting on a mix pot and a plate follower U2B = ECC82 as output
Why your choice was to ave a plate follower at the output instead of a CF ?
Offline Lauri
« Reply #12 on: September 02, 2014, 08:08:04 am »
With cathode follower as the output stage the output signal would be 180 degrees out of phase with the input signal. Which usually isn't a problem but I wanted the input and output to be in phase in case I use it in parallel with something else.
« Reply #13 on: September 03, 2014, 10:12:46 am »
I understand, OK
Thanks for the answer
Offline Lauri
« Reply #14 on: September 04, 2014, 02:30:53 pm »
Here's another flip flop circuit that seems to work quite a bit better than the one in my earlier posts.
http://www.kolumbus.fi/~kp5188/musiikki/flipflop2.png
« Reply #15 on: September 16, 2014, 12:15:30 am »
Very ordinary.
But yes, grid-toggled is easier to slap than plate-toggled.
Tube-type is not critical. This specific plan has low-value resistors, so for a higher supply voltage you may need 12BH7 beef. But you could raise all resistances by a factor of 2 or 5 or 10 and use 12AU7. Would probably work with 12AT7 or 12AX7, real snappy.
R1 does not need to be scaled-up.
C2 C3 improve swithing time which might *not* be needed, or even best, for audio. I'd try leaving them out (save 12 cents and several solder joints).
D1 D2 could be 1N914-like small diodes; there's no need for 1 Amp parts here.
Offline willi-fx
« Reply #16 on: May 17, 2026, 11:00:47 am »
Hi Lauri,
a little bit late to the party, but would you be so kind to repost the schematics for the octave-down effect? The links are not valid any more.
Cheers
willi
Offline Lauri
« Reply #17 on: May 19, 2026, 05:02:47 am »
I've lost the schematic for the whole thing I built. I was able to find schematics for the basic tube octaver circuits.
« Last Edit: May 19, 2026, 05:35:59 am by Lauri »
Offline willi-fx
« Reply #18 on: May 19, 2026, 02:26:07 pm »
Thank you very much!!  :worthy1:
What voltage would you use for B+? 300 V?
Offline Lauri
« Reply #19 on: May 19, 2026, 02:38:05 pm »
Anything between 200-350V should work just fine.
« Reply #20 on: May 19, 2026, 03:05:02 pm »
Sounds good. Are you sure that first schematic (octaver.png) actually works???
Offline Lauri
« Reply #21 on: May 20, 2026, 02:35:02 am »
That's the circuit in the octaver in the video.
Offline willi-fx
« Reply #22 on: May 20, 2026, 11:59:08 am »
Very convenient, this means I can use my booster instead of building a power supply.
Offline willi-fx
« Reply #23 on: May 20, 2026, 12:32:26 pm »
I suppose the volume pot goes after C11.
Where did you place the gain? Next to R5?
Offline Lauri
« Reply #24 on: May 20, 2026, 01:27:07 pm »
Low pass filter goes after C11. There's a amplifying stage for the clean signal and a mix circuit but that's the part of the schematic I've lost.
Offline Lauri
« Reply #25 on: May 21, 2026, 08:48:59 am »
Here's a full schematic for a tube octaver. Some resistor values might need adjusting depending on the supply voltage.
« Last Edit: May 21, 2026, 12:11:52 pm by Lauri »
Offline willi-fx
« Reply #26 on: May 21, 2026, 01:50:57 pm »
Oh, so this is an amp with built in octaver effect, not a standalone octaver effect...
« Last Edit: May 21, 2026, 02:57:53 pm by willi-fx »
Offline Lauri
« Reply #27 on: May 22, 2026, 05:08:20 am »
It's a standalone octaver effect.
