September 15, 2026, 01:57:19 pm
Hoffman Amps Forum image Author Topic: 2 conductor, shielded cable for heaters?  (Read 7456 times)
Offline hesamadman
« on: September 04, 2014, 06:39:15 am »
anyone ever done this?
Re: 2 conductor, shielded cable for heaters?
« Reply #1 on: September 04, 2014, 07:40:56 am »
I did. Once.
Offline hesamadman
« Reply #2 on: September 04, 2014, 08:02:57 am »
I did. Once.
What are your thoughts? Did it work well?
« Reply #3 on: September 04, 2014, 08:33:38 am »
Works fine. Too much trouble for no benefit. I thought it would look neat, but it really looks messier that a simple twisted filament string.
« Reply #4 on: September 04, 2014, 11:05:06 am »
My opinion (and as said is only my opinion) is that the problem of emission of heater wires is a magnetic field due to the high current
not other kind of emission,
twisting wires we discourage this magnetic field going far from conductors
I don't see a good shield for magnetic field in aluminium, copper or brass
the only good shield is iron (of course Mu-metal is the top, but not easy to have)
so I don't believe that a copper mesh or aluminium foil can be a good shield for EMI
and I think that if you want to shield heater wires you must use a small pipe made by thin iron foil
no standard shielded cable is usable with high benefits to me
much better to twist and route properly heater wires
« Reply #5 on: September 04, 2014, 12:31:48 pm »
The thing that cancels the hum is the twisted pair, not shielding
You get a better twisted pair from 20 gauge solid core wire
« Reply #6 on: September 05, 2014, 12:15:48 am »
Thick iron.
Or thin mu-metal.
However when directly against high-current wires, either material will *saturate*. Then it is no better than air, and a lot more work.
Conductive (copper etc) shielding "should" help some. But I don't think I have ever seen it done. Sluckey says he did, and I trust his "not worth it" opinion.
Twisted up-to-the-pins balanced AC has always been "good enough" for regular guitar amps.
Super high-gain, like mike amps, limiters, and the very-best head-banger amps, must turn to DC heat.
Also most PCB amps "should" use DC (can't twist on PCB).
Offline hesamadman
« Reply #7 on: September 05, 2014, 06:35:49 am »
Thick iron.
Or thin mu-metal.
What do those guys use to get their DC power for filaments?
Offline Merlin
« Reply #8 on: September 05, 2014, 09:20:51 am »
Most common forms of heater hum are caused by the electric field rather than the magentic field. Unfortunately, most of the electric coupling takes place *inside* the valve, so shielded cable cannot help this very much.  :sad:
« Reply #9 on: September 05, 2014, 10:17:15 am »
Yep, this is about as crammed as it gets with four cascaded gain stages and no hum, interference, or parasitic oscillation what so ever. (drgonzonm you link doesn't work)
« Reply #10 on: September 05, 2014, 02:12:49 pm »
[/quote]
I've done 2 dc filament builds in preamp sections, I use a 12vac 2A tranny, bridge, about 2200 to 4700uf into a heatsinked 12volt 1.5a regulator, same cap size out, plus a .01uf downstream.  both had 4 12....7s
