September 14, 2026, 07:49:52 am
Hoffman Amps Forum image Author Topic: ROTOSONIC II  (Read 10296 times)
ROTOSONIC II
« on: September 13, 2014, 05:38:51 pm »
Hi guys, I've got an even poorermans Leslie, as this one is only a single speed.
I did some searches to see if it could have a speed control added, but nothing that I could under stand
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
Re: ROTOSONIC II
« Reply #1 on: September 17, 2014, 10:05:05 pm »
Original 2 speed Leslies have actually 2 motors, fast and slow. The modern Leslies use just the "Fast" motor but use a "Pulse" circuit that provides AC in pulses so the motor cannot achieve full speed, the kits to convert Leslies to do that are rather expensive. https://bborgan.com/hamptone-mk1c-motor-control.html
Open Minded But Fixed Bias
Re: ROTOSONIC II
« Reply #2 on: September 17, 2014, 10:25:27 pm »
The modern Leslies use just the "Fast" motor but use a "Pulse" circuit that provides AC in pulses so the motor cannot achieve full speed......
Ahhhhh........    interesting.
                  Brad     :think1:
Re: ROTOSONIC II
« Reply #3 on: October 04, 2014, 11:49:40 pm »
Hi guys, The SS amp side of this build http://el34world.com/Forum/index.php?topic=17531.0 has past the sound check.
The use of the 50w module is so much quieter than the old stuff.
Just need to sort out a power supply for the 12v relays. I was hoping to use the +15v for the EQ and add a dropping resistor to get around 12v. Can this be done. Thanks
Re: ROTOSONIC II
« Reply #4 on: October 10, 2014, 06:22:54 pm »
Hi guys, I been having a few problems sorting out the electrics for the switching and power supplies. So things are a bit slow on the construction side.
Re: ROTOSONIC II
« Reply #5 on: January 10, 2015, 09:23:03 pm »
Hi guys, How time flies.
With some distractions out of the way and the wait for parts, the end is here for the "ROLASONIC VIBRATO"
I'll get some sound clips ASAP. :icon_biggrin:
Offline stingray_65
Re: ROTOSONIC II
« Reply #6 on: January 10, 2015, 11:17:29 pm »
WOW!
I've always knew something like this was possible, but never got around to searching out how one would use one of those leslie units.
I think I have 3  maybe 4 of those leslie units in storage
I have a larger one with a wooden rotor that used to be a 2 speed that i put a PWM controller and motor on it to make it a fully variable speed.
I harvested them from old organs and I used the swell pedal to vary the speed.
never mounted it in a cab or anything.
I think I know what my next project is going to look like!
This is so cool!
Ray
Re: ROTOSONIC II
« Reply #7 on: January 11, 2015, 12:43:24 am »
Hey stingray, I look at those variable speed controls but the cost is a killer and I didn't find much in a DIY unit. Can you elaborate on the PWM. Thanks
Offline SILVERGUN
Re: ROTOSONIC II
« Reply #8 on: January 15, 2015, 11:34:14 am »
Nice work TIMBO!!   :occasion14:
Here's a little reading on PWM, as it applies to DC motors:
http://www.electronics-tutorials.ws/blog/pulse-width-modulation.html
Here's an example of a schematic that we use for a wire feeder to control wire speed in a welding machine, just to give you an idea of how the circuit looks.
If I was gonna try it I'd just cheat and steal the control board and motor out of an old feeder.  :icon_biggrin:
Re: ROTOSONIC II
« Reply #9 on: January 15, 2015, 11:44:31 pm »
 :huh:
Re: ROTOSONIC II
« Reply #10 on: March 11, 2015, 02:17:57 am »
