August 29, 2026, 01:58:46 pm
Hoffman Amps Forum image Author Topic: Has anyone done a comparative test between cathode follower and source follower?  (Read 5445 times)
That a mosfet as source follower give good sound result if used in a tube amp there is more of an example here in the forum
and Tubenit is surely one of the guy who experimented a lot with this architecture
What I would like to know is if anyone has done a comparative test between a CF and a SF (in the same circuit)
as to listen to the subtle difference between the two
I've used IRF820 source followers in buffer stages for bias-vary tremolo in several amps, but that isn't in the signal path. However I can say that high-voltage mosfets (as SF) do work well for LFO buffering, and it saves the worry about h-k insulation breakdown that you can get with modern tube CF stages.
Hi Tubeswell
This response does not answer my question, but despite this, it is an interesting subject and I'm glad you've shared your experience
Here an interesting article about CF vs SF
http://milas.spb.ru/~kmg/irf_en.html
Franco,
Found this:
http://amtelectronics.com/support/articles/source-follower-on-the-high-voltage-mosfet-as-cathode-follower/
And this is an interesting discussion:
http://www.diyaudio.com/forums/analogue-source/11386-common-cathode-triode-vs-source-follower-hexfet.html
Although I'm not sure any of these answer your sonic question.  Interesting subject.
Many Thanks Ritchie
Interesting links
