September 15, 2026, 12:25:19 am
Hoffman Amps Forum image Author Topic: low wattage el34 amp  (Read 32836 times)
Re: low wattage el34 amp
« Reply #50 on: June 22, 2016, 04:09:34 pm »
You guys don't have to stick to SE designs to get the lower power output; Marshall has at least one new amp (maybe several) on their website with push-pull EL34's for a rated 20w RMS.
Assume it also means lower supply voltage and cathode biasing.
Offline Paul1453
« Reply #51 on: June 22, 2016, 04:30:46 pm »
I'm just trying to make the best use of my little SE OTs.   :l2:
Also around 10W from a 250V B+ is plenty of power for a home practice amp.   :icon_biggrin:
If I use 2 EL34s I want to get around 50W output for a real gig-able amp.   :dontknow:
