September 15, 2026, 05:49:06 pm
Hoffman Amps Forum image Author Topic: Has anyone ever tried this type standby ?  (Read 5083 times)
« on: October 15, 2014, 02:38:27 am »
I was wondering if someone has ever tied this particular standby circuit
 I'm curious about performances
also I don't understand which is the purpose of the DPST relay (if it isn't part of the standby)
« Last Edit: April 25, 2024, 12:29:18 pm by kagliostro »
Re: Has anyone ever tried this type standby ?
« Reply #1 on: October 15, 2014, 06:43:33 am »
I've used a 47k/3W resistor across a standby switch before,and it worked fine. I put mine in before the PT, that way it lowered the voltages to everything. Haven't bothered with it again since the consensus seems to be that, for lower powered amps it's not necessary.
The DPDT seems to be part of the standby circuit (lifts the ground to the top 2 windings) but I also think the dotted rectangle is drawn incorrectly. It shouldn't include the resistor--- unless that's not the resistor but the coil for the relay. Same thing with the other rectangle, not sure what's going on there.
« Reply #2 on: October 15, 2014, 07:10:31 am »
Thanks for the answer John
Within the rectangle there is the relay coil, and the standby isn't there (at least so it seems to me)
Look to the right in the schematic, it is labeled "Standby switch SPST"
it acts disconnecting grids from power and connecting the grids to the negative voltage of the bias supply
a bit odd to me (I haven't seen one other circuit do in that way) but intriguing and maybe high-performance
« Reply #3 on: October 15, 2014, 08:06:15 am »
also I don't understand which is the purpose of the DPDT relay (if it isn't part of the standby)
It's a safety interlock. The bias supply must be working to energize the relay. If for some reason the bias supply fails the B+ and screen supplies will be switched off.
« Reply #4 on: October 15, 2014, 10:01:57 am »
Many Thanks Steve
Offline darryl
    • ValveTone Amplification
« Reply #5 on: October 15, 2014, 06:11:54 pm »
The amplifier in my avatar ( and all the other amps I built in the 1970's ) uses a simplified version of that standby. It disconnects the output valve screen supply, but does not connect the screens to the bias supply.
Using the bias to apply a negative voltage to the screens is a good idea. It would ensure the output valves were completely cut off in standby. My amplifiers would bleed a tiny, distorted signal if a large input signal was applied to the amp whilst in standby.
These days I don't even bother with a standby switch.
« Reply #6 on: October 16, 2014, 01:39:30 am »
Many Thanks for the info Darryl
