September 08, 2026, 09:45:50 am
Hoffman Amps Forum image Author Topic: How to double check your amp wiring and find things you missed  (Read 75638 times)
« on: October 18, 2014, 08:28:22 am »
I created this animation that shows how well the tracing technique works for double checking your work
Please do this first before posting questions in the forum
Hoffman's law states the the amp would be working if everything was correct
(1) Print your layout in grayscale on your printer
(2) Use a colored sharpie or highlighter pen
(3) Start at the left end of the paper diagram and put your finger or a wooden chopstick on the part or wire you are checking
(4) Check all jumper wires, parts values and wires leading to and from the board
(5) If the part or connection is correct, then highlight that on your diagram
When you are done, if something is not highlighted, then you missed checking that item or you connected something wrong
The animated diagram below will cycle through 6 different images
This just gives you a good idea how the process works
« Last Edit: February 25, 2020, 08:03:03 am by EL34 »
Offline archaos
Re: How to double check your amp wiring using and find things you missed
« Reply #1 on: October 18, 2014, 03:05:50 pm »
Cool, thanks !
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline MakerDP
« Reply #2 on: October 18, 2014, 04:01:08 pm »
That is a great method.
I actually take it a step further and highlight both my layout diagram and the schematic. That serves as a double-check against my layout and a triple-check against my wiring. I do it as I build too.
It's also a great way to document a build that you've tweaked and forgot/was-too- lazy-to document what you changed as you did it.
« Reply #3 on: October 18, 2014, 05:40:04 pm »
excellent method
I wish all were that thorough with their builds
« Reply #4 on: October 18, 2014, 07:37:05 pm »
i use a pencil instead of a highlighter. when i check the layout against the schematic, is when i mark up the schematic.
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: October 19, 2014, 08:43:00 pm »
Highlighting the schematic and the layout drawing simultaneously also helps find any inconsistencies between the two.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline MakerDP
« Reply #6 on: October 19, 2014, 10:43:50 pm »
excellent method
I actually found an error on someone else's layout doing this! Fortunately it was before I soldered anything but it was after I installed the turrets.
(Don't worry, it was on another amp-building site  :icon_biggrin: )
« Reply #7 on: October 20, 2014, 07:04:39 am »
I only do that when first designing my Turret Boards
By build time the layout should be 100% correct and good to go
« Reply #8 on: October 20, 2014, 07:26:58 am »
I like to use a highlighter on busy schematics when drawing a board layout. I also use a highlighter when installing jumpers on a complicated turret board such as this. So far I haven't missed or misplaced any jumpers. It would not be funny to discover a missing or misplaced jumper during troubleshooting, especially if it was under the board!
« Last Edit: July 16, 2016, 09:35:29 am by sluckey »
« Reply #9 on: October 20, 2014, 07:35:16 am »
Yeah, that would suck to find out later you missed a jumper
You could do a top jump, but it would not be as pretty
