September 17, 2026, 08:44:55 pm
Hoffman Amps Forum image Author Topic: Bad Cat Hot Cat 15 Schematic  (Read 17859 times)
Offline bnwitt
  • Crankin' out the tone.
« on: October 22, 2014, 11:56:30 am »
Does anyone in here have a schematic and/or other details on the Bad Cat Hot Cat 15 amplifier?  I just picked up one of the Chinese made Bad Cat Cougar 15 amps that I want to gut and change to the Hot Cat 15 or the Vox Handwired AC 15.  Thanks in advance
Barry
Re: Bad Cat Hot Cat 15 Schematic
« Reply #1 on: October 22, 2014, 12:06:50 pm »
Maybe this with only 2 EL84's ??
http://el34world.com/charts/Schematics/files/_Miscellaneous/badcat_hotcat_30.pdf
Offline bnwitt
« Reply #2 on: October 22, 2014, 05:58:45 pm »
Thanks Tubenit.  I do appreciate it.  I've got that one.  I'm sure the two amps are similar.  I was hoping to find the 15 schematic to make sure.  I'm assuming the 15 has EL84 power tubes though
« Last Edit: October 22, 2014, 06:02:37 pm by bnwitt »
Offline bnwitt
« Reply #3 on: October 23, 2014, 10:16:01 am »
Is it just me or does the PI and MV in that schematic look odd?
« Reply #4 on: October 23, 2014, 11:24:03 am »
The PI is just a standard garden variety LTP. The MV is a bit odd. It will not vary the signal very much and won't even get close to zero volume.
« Reply #5 on: October 23, 2014, 11:29:14 am »
I'll 2nd odd on the pi, the MV is one I've seen a couple times.  by other threads it appears this type is "less liked".
« Reply #6 on: October 23, 2014, 03:44:52 pm »
I'll 2nd odd on the pi...
What's odd about it? I'm looking at the schematic posted by tubenit. Maybe I'm looking at the wrong schematic?
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #7 on: October 23, 2014, 10:39:11 pm »
The four-stage pre-amp, the 10K screen resistors, and the additional 100uf for the plates on SS rectifier all clearly indicate an amp designed for extreme overdrive.  A master volume that doesn't work fits right in.  Or maybe he meant for the 220K to go to the 100K pot and the wiper to go to "F".
« Reply #8 on: October 24, 2014, 08:50:02 am »
You "fixed" the odd for me by stating the obvious that I missed, LTP.  I got hung up on each side of the PI being fed by 2 dif channels n missed what the PI actually was.
thanks again
« Reply #9 on: October 24, 2014, 09:12:59 am »
...each side of the PI being fed by 2 dif channels...
That's fairly common in amps with a LTP if they don't use one input for NFB. Marshall 1974 (commonly called 18 Watt), Vox AC-15, and some AC-30s do it. And the Matchless Chieftain even uses the second input to mix reverb back into the dry signal. That second grid on the LTP is up for grabs for a lot of ideas, but it it's not going to be used for anything, it should sit at AC ground, usually via a cap to ground.
Offline bnwitt
« Reply #10 on: October 26, 2014, 10:09:35 am »
Steve,
Thanks for that explanation.  I did not know that. :smiley:
Offline bnwitt
« Reply #11 on: October 28, 2014, 10:33:23 am »
Ok so I guess I'm stuck with the 30 watt schematic for this amp but evidently there are some errors in that schematic.  Below is a link to a thread that has user Loudthud pointing this out:
http://music-electronics-forum.com/t19757/
Barry
