September 17, 2026, 09:44:58 am
Hoffman Amps Forum image Author Topic: ECL 86 ?  (Read 7123 times)
Offline Toxophilite
ECL 86 ?
« on: October 25, 2014, 01:18:31 am »
Anybody do anything interesting with the pentode/triode ECL 86 ?
I have a few telefunkens still sealed in their original boxes. Wondering what to use them for.
Oh and could one use a EL84 single ended OT for a revibe as I have an old grundig reel to reel that might be good parts (PT and OT and choke) for a revibe build
Re: ECL 86 ?
« Reply #1 on: October 25, 2014, 02:22:12 am »
This is only an example
Full info here
http://paulamps.com/6gw8-2.html
One other possibility
http://el34world.com/Forum/index.php?topic=13337.msg124714#msg124714
Tubenit for sure has someting of interesting to show to you
« Last Edit: October 25, 2014, 02:27:29 am by kagliostro »
Re: ECL 86 ?
« Reply #2 on: October 25, 2014, 07:08:53 am »
This idea uses a 6BM8 but you certainly could substitute the ECL86 IF you have a lower B+ rail.
AND if you had a low enough PT like 190-0-190 with enough ma current,  ............ you could use a solid state rectifier and get the build down to just 3 tubes.
https://www.edcorusa.com/xpwr012
https://www.edcorusa.com/xpwr100
The schematic I'm showing you is pretty close to the topology on the SoLow Watt amp I built.
http://s28.photobucket.com/user/tubenit/media/SoLowWattampcab.jpg.html?sort=3&o=7
« Last Edit: October 25, 2014, 07:21:03 am by tubenit »
Re: ECL 86 ?
« Reply #3 on: October 25, 2014, 07:11:57 am »
There are a bunch of low watt push/pull ideas here:
http://el34world.com/Forum/index.php?topic=12526.0
Re: ECL 86 ?
« Reply #4 on: October 25, 2014, 08:09:24 am »
The Hammond AO-44 uses that tube. Here's my conversion project...
http://home.comcast.net/~seluckey/amps/PeeWee/peewee.htm
That EL84 SE OT should work fine in the revibe circuit.
Re: ECL 86 ?
« Reply #5 on: October 25, 2014, 10:03:59 am »
Sluckey,
I forgot that you built that.  That's a really super nice amp design!  Thanks for sharing it!
Best regards, Tubenit
Re: ECL 86 ?
« Reply #6 on: October 25, 2014, 01:56:50 pm »
the OT probably. the PT probably as well, but it would be nice to know what the winding output specs are.
Re: ECL 86 ?
« Reply #7 on: October 25, 2014, 11:24:52 pm »
ECL82 or ECL86 both make great reverb driver/recovery tubes in a 1 tube reverb
Re: ECL 86 ?
« Reply #8 on: October 26, 2014, 02:43:54 am »
Hi Toxo, As tubeswell said, these TV type tubes were all our early amp builders could get there hands on and they made great amps with them.
http://www.ozvalveamps.org/goldentone3.htm#practice
http://www.ozvalveamps.org/playmaster.htm
