September 17, 2026, 08:45:17 pm
Hoffman Amps Forum image Author Topic: revibe question  (Read 5160 times)
Offline Toxophilite
revibe question
« on: October 30, 2014, 12:12:22 am »
Can I build a 6V6 revibe using a transformer set(PT and OT) from a single ended El84/6BQ5 amp? (an old grundig reel to reel)
or do I need specific 6V6 transformers (I'm pretty sure it's mostly the OT that might be specific)
THanks
Re: revibe question
« Reply #1 on: October 30, 2014, 03:45:37 am »
THanks
yes. it will likely work. what's the B+ of the grundig?
Offline Toxophilite
Re: Revibe EL 84 transformer set Question
« Reply #2 on: November 21, 2014, 10:37:24 am »
Sorry for the delay
Other projects intervened
I get around 260 vdc at the EL84 and around 270 closer to the PT..I did this quickly this morn so I haven't found where the rectifier is hiding yet
THanks
Re: revibe question
« Reply #3 on: November 21, 2014, 10:48:21 am »
if grundig OT was used to drive an 8ohm load, it'll work.
Offline Toxophilite
Re: revibe question
« Reply #4 on: November 22, 2014, 04:59:24 pm »
Oh heck 4 ohms
Can I use a different tank, something with a 4ohm load?
Re: revibe question
« Reply #5 on: November 22, 2014, 07:47:09 pm »
The OT that Hoffman sells for the Revibe has a 4Ω secondary. So does the OT I used on my Revibe. A 4Ω OT works very well with an 8Ω tank. Besides, you may not find a 4Ω tank.
Re: revibe question
« Reply #6 on: November 22, 2014, 09:07:45 pm »
It's a teeny reverb tank, not a speaker into a 750 seat club.
4, 8, 16, whatever... just do it. The difference in "power" (milliWatts) is unimportant.
The "problem" is in mixing 8 (4, 16) drivers and tanks with 600 Ohm drivers and tanks. That's enough mis-match to cut the spring drive way off.
Offline Toxophilite
Re: revibe question
« Reply #7 on: November 23, 2014, 02:30:16 pm »
Excellent
THanks very much!
Time to start pulling apart the grundig
