September 14, 2026, 02:27:03 pm
Hoffman Amps Forum image Author Topic: coupling caps  (Read 7007 times)
coupling caps
« on: November 12, 2014, 01:08:34 pm »
A lot of the coupling caps in the schematics I've been looking at are electrolytes, I'm trying to "get" which way they go, just when I think it makes sense I find a schematic with it flipped.  what determines where the + goes?  thanks
Re: coupling caps
« Reply #1 on: November 12, 2014, 02:50:29 pm »
If it's in a circuit that also has DC voltages present, the positive end goes to the most positive dc voltage. If in a totally AC circuit, it doesn't matter.
Re: coupling caps
« Reply #2 on: November 12, 2014, 05:53:52 pm »
Thanks, makes perfect sense when you put it that way!  sorta forgot my sandtronic basics.
Re: coupling caps
« Reply #3 on: December 20, 2014, 07:24:51 pm »
If the cap is in-line with the signal then the + side goes towards where the signal is coming from and the negative towards where it's going next... think of it like: (+++it went that-a-way--->)  :laugh:
