September 18, 2026, 03:33:56 am
Hoffman Amps Forum image Author Topic: Laney VC50 Tube Amp Hum Problem  (Read 4237 times)
Offline scott1968
« on: November 24, 2014, 09:22:26 pm »
I have a Laney vc50 tube amp that does nothing but hum (quite loudly) when you turn the standby switch on. What is going on with this thing????
Offline AZJimC
  • What a pretty glow!
Re: Laney VC50 Tube Amp Hum Problem
« Reply #1 on: November 25, 2014, 02:06:39 am »
If the Vol control does not effect it, then first place I'd look is output tubes or power supply caps
Offline Jack_Hester
  • Greybeard
« Reply #2 on: November 25, 2014, 06:35:59 am »
If the volume control does affect the hum, you may want to head over to the input jacks.  They appear to be closed circuit types, and ground the input if not in use.  One or both of these being open (not grounded) with no instrument connected can possibly be a problem.  Especially, when you turn the volume up.
Jack
"We sleep safe in our beds
                                                   ---George Orwell
