August 01, 2026, 08:21:22 am
Hoffman Amps Forum image Author Topic: Plexi 6V6 Hoffman style  (Read 38166 times)
Re: Plexi 6V6 Hoffman style
« Reply #50 on: January 17, 2015, 03:55:57 pm »
nice. very, very nice!  :-)
« Reply #51 on: January 17, 2015, 05:14:31 pm »
Curious about the working voltages in the amp
I guess you will be updating your PDF files with that?
« Reply #52 on: January 17, 2015, 05:47:15 pm »
Wish I could do a demo but I'm just not set up for that.
As an side FYI to everyone,  I met Sluckey some years ago & we got to jam. It was a lot of fun for me.  He is an excellent guitarist and is a better player than I am, IMO.  He knew all kinds of stuff and was kind enough to share some of it with me.
And he is just a great person also.  It was a really a treat to meet him.
« Reply #53 on: January 17, 2015, 06:13:32 pm »
Doug, node A is 400V with a GZ34 and running the bias at 25mA. It was 370V with a 5Y3. I like the GZ better. I'll post all voltages in the updated pdf. Stay tuned.
Jeff, you're too kind buddy.
« Reply #54 on: January 17, 2015, 09:50:27 pm »
I've updated the pdf file to include actual voltage readings on the schematic. I've also shown a couple minor changes. I'll post the entire web page in a couple days.
     http://home.comcast.net/~seluckey/amps/6v6plexi/6v6plexi.pdf
« Reply #55 on: January 18, 2015, 04:17:52 am »
WOW Steve !!!
beautiful work  :thumbsup: :thumbsup: :thumbsup:
You beat yourself
Thanks for sharing
Offline drew
« Reply #56 on: January 18, 2015, 01:36:27 pm »
If you were going to do it again, would you just go with solid state rectification?
« Reply #57 on: January 18, 2015, 01:38:45 pm »
I would include a tube socket for a tube rectifier for those that want that but I would plug in a solid state rectifier in that socket for me personally.
« Reply #58 on: January 18, 2015, 02:02:24 pm »
No. I wouldn't change a thing about the way I built this.
However, I initially laid out the board for SS rectifier diodes. Doing so adds 1/2" to the board length, but it allows the tubes to be spread out more on the chassis if you drop the rectifier socket. I thought a lot about dropping the recto socket but I'm glad I kept it.
« Reply #59 on: January 28, 2015, 11:16:42 am »
Hey Steve,
On your PDF schematic, you show two 100k plates load resistors on the phase inverter
It looks like you used a 82k and a 100K on your layout image
Also, the heaters don't show any ground reference
Did you use a pair of 100 ohms or did your tranny have a CT?
nevermind, I see now that you grounded one side of your heaters
« Last Edit: January 28, 2015, 11:32:04 am by EL34 »
« Reply #60 on: January 28, 2015, 12:17:14 pm »
Hmm. Look again. The top triode (V3-A) has a 82K plate load. Maybe you're looking at the 100K grid resistors for the 6V6s?
My PT has a real CT. It's shown on the "Mains Wiring" page. You can also see the green wire connected to a ground lug near the cap cans in the close-up gut shot pic. My schematic is wrong. I'll fix that. That's what I get for using so much copy/paste between schematics.
Are you drawing up a Hoffman style board layout? If so, I'd love to get a copy of the Visio file.
« Reply #61 on: January 28, 2015, 12:27:02 pm »
I must have been looking at something else while I was doing 3 things at the same time  :icon_biggrin:
working on a layout right now
just started today so it may be a while
Offline JBP
« Reply #62 on: January 29, 2015, 07:39:40 am »
The tranny I'm using does not have a CT for the heaters. Do I need to create one with 100 ohm resistors ? Jeff
« Reply #63 on: January 29, 2015, 07:47:03 am »
yes
« Reply #64 on: January 29, 2015, 01:36:12 pm »
Here's is my first draft of the Hoffman Plexi 6V6
I still have to rename all the parts on the schematic and do some other stuff
Copy and pasting things from other files always has snags
http://el34world.com/Hoffman/files/Hoffman_Plexi_6V6.pdf
Let me know if you see any obvious errors
I have not spent much time double checking things yet
Eyes are tired and I am stopping work on this project today
The filter cap values are not all correct on the PDF file yet
[40uf x 20uf x 20uf x 20uf] cap can + 16uf is what I designed
« Last Edit: January 29, 2015, 05:31:46 pm by EL34 »
« Reply #65 on: January 30, 2015, 11:13:27 am »
Here is version 2 with a shorter board
Plexi 6V6 version 2
http://el34world.com/Hoffman/files/Hoffman_Plexi_6V6-V2.pdf
Screen grids are on the sockets
100k plate load is on a socket
Thanks to steve for the suggestions
The board size is down under 7 inches now
« Reply #66 on: January 30, 2015, 11:30:11 am »
Recheck the wiring on V2. Red wire goes to pin 6. Resistor goes between pin 6 and pin 1. Jumper from pin 1 to pin 7.
« Reply #67 on: January 30, 2015, 11:33:07 am »
yeah, thanks
I can only do this for so many hours before I get tired of staring at the screen
I uploaded a fresh copy of the PDF with the fix
Thanks for double checking
I was headed out the door to get away from the computer for a while :)
« Last Edit: January 30, 2015, 11:40:29 am by EL34 »
« Reply #68 on: January 30, 2015, 11:42:51 am »
On the next batch of Stout chassis i think it would be a good idea to add another pre amp tube hole in addition to the other changes we came up with a while back
« Reply #69 on: January 30, 2015, 02:03:32 pm »
I think that's a good idea also. Definitely help increase options in using that amp chassis.
Offline MakerDP
« Reply #70 on: January 30, 2015, 02:50:17 pm »
Plexi 6V6 version 2
Hey I really like this. Easily convertible to a JTM45 w/KT66 with a couple component changes also!
« Reply #71 on: January 30, 2015, 02:52:16 pm »
The official Stout Chassis thread is here if you guys want to add your comments
http://el34world.com/Forum/index.php?topic=17502.150
Offline hardhead
« Reply #72 on: February 02, 2015, 09:07:56 am »
Plexi 6V6 version 2
That is one "slick whistle"....when do you have time to sleep, Doug
« Reply #73 on: February 02, 2015, 09:14:17 am »
« Reply #74 on: February 02, 2015, 10:41:25 am »
Sluckey, that's a nice lookin' amp and the documentation is top-drawer. I bet it sounds great.  Thanks for sharing.
« Reply #75 on: February 04, 2015, 12:28:33 pm »
Here's version #3 of the Plexi 6V6
This version has the Blend control, pre amp volume and a master volume
http://el34world.com/Hoffman/files/Hoffman_Plexi_6V6-V3.pdf
« Reply #76 on: February 05, 2015, 04:31:15 pm »
Version 2 is the dual volume pot version
Version 3 is the Blend and Pre Volume version
I want to see how the V3 blend sounds first
I just may go back to the V2 dual volumes if I don't like V3
Offline pickinpop
« Reply #77 on: February 06, 2015, 12:28:39 pm »
so a new chassis with an extra preap tube hole is possibly in the future?
« Reply #78 on: February 06, 2015, 01:55:20 pm »
yes, and some other hole changes on the next batch
Gonna dial in this chassis so it can be used for many types of builds
Have to use up this batch of chassis first
« Reply #79 on: February 06, 2015, 02:16:16 pm »
Got quite a bit done today on the Plexi 6V6
Here's my build pic album on Facebook
Hopefully all the pics should be visible to you guys
https://www.facebook.com/media/set/?set=a.446459778835904.1073741838.264340103714540&type=3
Offline smackoj
« Reply #80 on: February 06, 2015, 07:13:10 pm »
Just a sort of wild ### question. does the 'Plexi 6v6' really sound like a lower power version of the early Plexi face Marshall, or are you mostly using the name based on the wiring design, component values etc?  I like the looks of that compact design for the Plexi or Stout chassis. nice work.
thanks
« Reply #81 on: February 06, 2015, 08:06:05 pm »
It's the Plexi circuit with 6V6's
That's why it's called a Plexi 6V6
I can't tell you what it sounds like yet, I am still wiring up the amp
« Last Edit: February 07, 2015, 06:37:46 am by EL34 »
Offline macula56
  • welcome to the bootyranch
« Reply #82 on: February 07, 2015, 06:03:48 pm »
I built one of these last year sort of based on Sluckey's layout but with KT66s in a 15 1/2" x 7 1/2" x 2 1/4" chassis. And since I don't really like cap cans I added a Deluxe Reverb dog house for my caps. I thought about tube rectification but I went with diodes for the rectifier. It fits inside of a Blackheart 15 Watt head cabinet. Rockin' Marshall tones and great cleans as well. Sort of a stealth amp as people see how small it is then hear the balls that come from it. A great circuit for sure and Sluckey's drawings are awesome.
« Last Edit: February 07, 2015, 06:07:44 pm by macula56 »
