August 02, 2026, 11:34:40 am
Hoffman Amps Forum image Author Topic: Grounding pin 2 & 7 of an ef86 - is feasible this way ?  (Read 7307 times)
« on: December 20, 2014, 11:40:53 am »
A friend has draw an 8 - 9 pin version of the 7 Cylinder amp (with some mod)
The layout is not yet complete but connecting to ground the pin 2 & 7 of the ef86 tube it was handy to use the shield of the cable of the input signal
is it feasible ?
p.s.: Here the .vsd file
http://www.mediafire.com/view/blsfad43y1jj2jt/9_Cylinder_Layout.vsd
Re: Grounding pin 2 & 7 of an ef86 - is feasible this way ?
« Reply #1 on: December 20, 2014, 12:07:11 pm »
The EF86 shield can ground at any point in the ground. No current flows through the shield that would affect the ground return.
« Reply #2 on: December 20, 2014, 12:54:14 pm »
yes. have seen,that done on an ampex preamp that uses ef86 first stage.
« Reply #3 on: December 20, 2014, 01:04:49 pm »
Molte grazie Tubeswell & Pete
