August 01, 2026, 11:43:29 pm
Hoffman Amps Forum image Author Topic: Princeton reverb master  (Read 7010 times)
Offline phsyconoodler
« on: December 21, 2014, 05:33:16 pm »
Anyone tried the train wreck type 3 master volume on a princeton reverb?
  Im thinking it should work but...
Re: Princeton reverb master
« Reply #1 on: December 24, 2014, 01:54:27 am »
Tried it. It gets resl gritty but has a hair trigger. On or off almost.
  Grinds really cool however.
i want to install the master that Merlin uses but its confusing me.
 It looks like the coupling cap from the previous stage is disconnected and hooked up to the pot.
   Anyway it eludes me how to implement it. Brain block.
« Reply #2 on: December 24, 2014, 05:30:00 am »
Keith,
Nice to see you on the forum!
You're presenting an interesting challenge given the PR has vibrato and fixed bias.  I probably would do a VVR and use it as the master volume.
http://www.hallamplification.com/main.html?src=%2F#2,2
« Last Edit: December 24, 2014, 11:11:48 am by tubenit »
« Reply #3 on: December 24, 2014, 06:06:21 am »
Edited info and reposted further in thread after help from Sluckey.
« Last Edit: December 24, 2014, 11:13:07 am by tubenit »
« Reply #4 on: December 24, 2014, 09:42:11 am »
That PPIMV circuit by Bruce Collins should work just fine in a PR.
« Reply #5 on: December 24, 2014, 09:46:01 am »
Steve, THANKS for the input on this!   I am understanding this to mean the vibrato will still work OK with the PPIMV.  Correct?
What about the other idea in reply #4 moving the vibrato ................ think that might also work OK?
Thanks! With respect, Tubenit
« Reply #6 on: December 24, 2014, 10:11:14 am »
Correct. Your draft circuit in reply #3 should work too.
This may work but will likely need some tweaking. If you had another triode you could copy the Vibro Champ circuit exactly.
I would try both of the other MVs before moving the trem.
« Reply #7 on: December 24, 2014, 11:24:11 am »
A LARMAR will work and the tremolo will also.  I have a PR build with one.  I do not care for it because the sound I like coming from a Princeton is not preamp.  It is not smooth at all.
I believe this is the perfect candidate for a VVR if someone is wanting a bedroom amp.
« Reply #8 on: December 24, 2014, 11:40:43 am »
Tubenit, you need to redraw that 68K and intensity pot sitting below the MOSFET.
« Reply #9 on: December 24, 2014, 11:56:27 am »
Sluckey's  response to my question whether the vibrato would still work:
Correct.
your bias tap (PT to 100K to 1n4007) is connected to supply mains directly. it will work but is not safe.
« Reply #10 on: December 24, 2014, 11:59:43 am »
corrected.
btw: in SCH if you set your snap to grid to .025" things fit better.
« Reply #11 on: December 24, 2014, 06:49:17 pm »
Corrected the schematics I previously posted.  CHECK for ERRORS!
« Reply #12 on: December 24, 2014, 07:40:16 pm »
So i ended up using the 5e3  style master.
one meg pot with one lug to coupling cap after first stage,wiper to pin 7 and end lug to the junction at the pi. It works pretty good. A little tweaking and it will be really good. I was going to use vvr  but didnt have therright mosfets on hand. Overall im happy. My brain got by its block! Thats the most important  thing.
merry Christmas  to one and all!
