September 16, 2026, 11:43:23 pm
Hoffman Amps Forum image Author Topic: Fender Twin Reveb II Schematic Help  (Read 4233 times)
Offline ncusack
« on: January 17, 2015, 11:03:28 am »
Hello,
I recently started a repair on a Twin Reverb II and I'm looking for an accurate schematic for it. The amp I have runs 4 6l6's and the schematic for the Twin Reverb II found in the library only shows 2. Before I dig too deep into this thing can anyone confirm what schematic I should be working from. If it helps the amp serial number is F404565.
Re: Fender Twin Reveb II Schematic Help
« Reply #1 on: January 17, 2015, 11:21:26 am »
The schematic only shows two tube symbols but if you look closely you'll see that the top 6L6 is referenced as V8, V9 and the bottom 6L6 is referenced as V10, V11 for a total of 4 tubes. The grid and screen resistors also have a (2) beside each so those are double quantity as well.
Offline ncusack
« Reply #2 on: January 17, 2015, 11:41:27 am »
Thanks for clarifying that one for me sluckey I must not have been squinting hard enough when I looked the first time.
