August 29, 2026, 01:11:35 pm
Hoffman Amps Forum image Author Topic: 5e9a speed pot  (Read 4786 times)
Offline Bugman3183
5e9a speed pot
« on: January 20, 2015, 07:06:00 am »
Good morning all.  I'm currently in the process of finding parts to build a 5e9a tremolux and can't seem to find a 2 meg "speed" pot.  I'm also not sure if it is an audio taper or linear pot (I'm thinking the latter).  I was also wondering if I could us  a depth pot with a switch as an alternative, or if I could just a seperate spdt on the front panel for the on/off switch.  Any help on this matter would be greatly appreciated.  Thanks.
Well, you know....sometimes you gotta race.
Re: 5e9a speed pot
« Reply #1 on: January 20, 2015, 09:15:51 am »
The 3M reverse audio taper pot that Hoffman sells will work just fine for the speed pot. You can use a depth pot with a push/pull switch or you can use a toggle switch. Either is fine.
Offline Bugman3183
Re: 5e9a speed pot
« Reply #2 on: January 20, 2015, 11:43:29 am »
Thanks for the reply sluckey.  That's good news, I actually have one of those pots on hand I got from Doug a while ago, so that's pretty convenient.  I really appreciate the advice.
Re: 5e9a speed pot
« Reply #3 on: January 20, 2015, 06:12:26 pm »
I stock a 2m linear pot, is that what you want?
Actually, they are out of stock right and should be here in a week or so
Offline Bugman3183
Re: 5e9a speed pot
« Reply #4 on: January 20, 2015, 06:40:45 pm »
Yes, that's what I was looking for.  Noticed they a been out of stock for a while.  I'll keep an eye on that and place an order when they come in since it won't be long from now.  Thanks.
