September 08, 2026, 07:13:52 pm
Hoffman Amps Forum image Author Topic: How to reduce Hum on a Blues Junior - An interesting read with uncommon solution  (Read 6105 times)
Here you can read the experience of a guy who was trying to solve a problem of Hum in a Blues Junior
the solution found is not common, but simple to implement
http://billmaudio.com/wp/?page_id=882
« Last Edit: February 26, 2017, 06:25:36 am by kagliostro »
If you read the content of the link
you can read:
I tested many, many configurations and materials.
and also that strangely an aluminium cylinder, used as shield, gived best results with respect to a mild steel can
However the author ended that the best solution is that shown on the photo (you can read the details on the link)
Offline vicentebd
nice see the positive result, with  angled piece of metal
at deluxe reverb level
Everything old is new again!
See attached photo of a circa 1962 Stromberg Carlson PA amp with vertical shield between a power tube and a socket for an optional relay (which would generate a magnetic field).
I was thinking more to a heat shield to protect the relays from the heat of the power tube
but may be it is as you say JJasilli
I never thought of that!  I just assumed it was as electromagnetic shield.   :dontknow:
Offline trobbins
    • Tim's projects and info
Definetly heat shield IMHO.
