September 16, 2026, 12:45:23 pm
Hoffman Amps Forum image Author Topic: Stout TMB build  (Read 4170 times)
Offline jly56
Stout TMB build
« on: February 21, 2015, 10:45:02 pm »
Hi..
Just finished building one of Doug's Stout TMB.  I went to fire it up and realized that I don't have a 5Y3 rectifier tube....  just some 5AR4/GZ34s.   Besides have a higher B+ (higher voltage drop on the 5Y3 than the GZ34), I can't think of any reason what it shouldn't work.... but figured that I would ask the board.
I noticed in the Stout TMB build page, the top picture shows a SSR Sovtek being used, and that would have an even higher B+ than a GZ34, would it?
Thanks for your responses.
Jeff
-Jeff
Online sluckey
Re: Stout TMB build
« Reply #1 on: February 21, 2015, 11:16:28 pm »
GZ34 will work fine. But you really want the B+ to be 350V or less. You can always knock it down with a NOS 5Y3 later if needed. I used a set of Doug's 18 watt iron and had a B+ of 342V using an EZ81.
Offline jly56
Re: Stout TMB build
« Reply #2 on: February 22, 2015, 01:18:14 am »
Thanks Sluckey...  Will toss in a GZ34 and see where my voltages are and go from there...  Never thought of a EZ81!  I'm also usings Doug's iron and could have used the 6v winding!
Did you make a head or a combo?  I'm trying to decide what speaker to put in the combo cab my wife (the wood worker) will build for me it.
Thanks again!
-Jeff
Online sluckey
Re: Stout TMB build
« Reply #3 on: February 22, 2015, 04:17:55 am »
I did a combo. Mine is actually a stock 1974 Marshall 18Watt circuit.
     http://home.comcast.net/~seluckey/amps/18w/18w.htm
I have an Eminence 15" Big Ben in the cab, but I prefer the sound through my 2x12 Celestion Heritage G12H cab.
« Last Edit: February 22, 2015, 04:29:10 am by sluckey »
