September 08, 2026, 06:25:56 pm
Hoffman Amps Forum image Author Topic: How to measure Impedance - Bandwidth - Efficiency of an OT - Here the solution  (Read 4804 times)
> Adjust the potentiometer R1, so R1+Rg is equal to the input impedance of the transformer.
While the "matched" condition is good to know, in many cases the transformer will be used UN-matched.
With solid-state drivers, the source impedance may be nearly zero.
With power pentodes, the source impedance is often 10 times the reflected load impedance.
For these cases you would measure the Frequency Response using the intended impedances.
In this days I'm trying to collect info about OT measurement
I would like to measure the bandwidth of an OT I've
Someone can report better methods than that indicated on the link ?
