September 17, 2026, 04:14:01 pm
Hoffman Amps Forum image Author Topic: Amp Switching Circuit Popping  (Read 9474 times)
Offline 8Len8
« on: March 21, 2015, 09:24:59 am »
I've get a Phaez amp that has 2 individual inputs, one for each channel. I decided instead of using an AB box that I'd install a switching circuit to route a single input to either channel.
Originally the amp had each channel's preamp tube connected to its own input jack.
I got a Granger optoFET channel select board:
http://grangeramp.com/shop/index.php?main_page=product_info&cPath=37&products_id=493
I powered it off a wall-wart and hooked it up like this (all connections via coax):
My only problem is that I hear a slight pop when switching from the clean to dirty channel. I've read that FET based channel select circuits should have quiet switching. Is there a pull-down resistor or something that I'm missing that could be causing the pops?  Even after I added the RC high pass filters the pop was still there...
Re: Amp Switching Circuit Popping
« Reply #1 on: March 21, 2015, 10:50:17 am »
Give a look to the way Sluckey do the commutation on his latest amp
no optocoupler, a simple DPDT switch
http://home.comcast.net/~seluckey/amps/dual_lite/Dual%20Lite.pdf
« Last Edit: March 21, 2015, 10:56:57 am by kagliostro »
Offline 8Len8
« Reply #2 on: March 21, 2015, 11:03:08 am »
My mistake.  Here's the correct schematic of how the circuit is wired:
« Reply #3 on: March 21, 2015, 11:18:13 am »
I would like to try a pair of 1M resistors across the switch (and maybe remove the 470k resistors ?)
Offline 8Len8
« Reply #4 on: March 21, 2015, 11:26:03 am »
I'll try that, but don't the tube inputs need a DC path to ground?
« Reply #5 on: March 21, 2015, 03:49:26 pm »
the question mark is because the presence of the in series 0.1 cap confuses me
Offline 8Len8
« Reply #6 on: March 21, 2015, 04:20:06 pm »
I added the 0.1 uF caps (the the 470K resistors) as a suggestion from another forum where I posted this problem.  Before then I just had the Granger Opto module directly connected to each preamp tube input pin.
« Reply #7 on: March 21, 2015, 04:34:18 pm »
I think if your search the forum for "channel switching" or "channel pop" you will find something about the 1M K is referring to.  FWIW here's a schematic with relays but the I think the 100k's and big caps are for switching type spikes, pops.
« Reply #8 on: March 21, 2015, 04:37:13 pm »
Try with the 1M resistors and without the cap and the 470k resistors
If the previous didn't solve, try also this configuration
I really would like to know if using a simple DPDT switch the pop is present
« Last Edit: March 21, 2015, 04:57:06 pm by kagliostro »
Offline 8Len8
« Reply #9 on: March 21, 2015, 05:05:57 pm »
I'll try the 1M resistors next week when I can get my hands on some.  I'd need a pretty quiet DPDT switch to try out your recommendation so I wouldn't be confusing the switch noise with the amp circuit noise  :).
Offline 8Len8
« Reply #10 on: March 27, 2015, 05:21:31 pm »
I tried the top mod (1M resistors) and the pop is still there.  I'm not sure removing the caps would do anything.
« Reply #11 on: March 27, 2015, 06:16:14 pm »
I don't say it can solve, but try to remove the cap
a charged cap when switched on give a pop
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #12 on: March 28, 2015, 03:38:34 pm »
Those dirty channels generally have huge gain making the input very sensitive.  I always move the switching down the line someplace where it isn't near as sensitive.  I used to use H11F3's, which is an infrared LED controlled bilateral FET.  The things could handle a 30Vp signal, so it was possible to use it after the first stage.  I don't know what your device will handle, but I'd bet that it is similar.
By the way, I quit using H11F3's because they added a subtle sound to the amp even when only used to short the signal to ground.  In fact, I have found that any SS device touching your main tube preamp circuit in any way adds a sound to it.
