September 18, 2026, 05:41:43 am
Hoffman Amps Forum image Author Topic: My first amp build (18W)  (Read 6556 times)
Offline pickdropper
« on: March 22, 2015, 07:11:07 pm »
I started this half a year ago, but life is busy so it took me a while to chip away at it.  I went with a Mojotone kit for this build, but there's definitely a Hoffman board in my future.  I like the idea of being able to choose all my own parts.
I took a LONG time wiring this one since it was my first.  Twisting up the heater wires was a royal pain.  That was my least favorite part of it, but it came out OK.  Here is a pic with it partially wired.
It's mostly wired here:
Here it's getting tested.  I didn't build a dim bulb tester for this.  I ended up using a Variac to slowly bring it up and check the voltages.
All done.  I decided to call it "Stonehenge" as it looks like a small half stack that's in danger of being crushed by a Dwarf.   :icon_biggrin:
I am going to have to add some sort of power scaling.  It has a great clean tone at lower levels, but I need to really crank it to get it crunchy.  Scaling it down will help when I have it at home.  I've borrowed a Hot Plate from a friend for now, but I think an internal solution would be better.
This thing has just a ton of low end.  With the 75Hz greenback and a sealed cab, there is quite a resonance at the low A (110 Hz).  Opening up the cab should help, but I may have to change to a 55Hz speaker or drop the value of the cathode bypass cap (or put in a switch for different options).
There is also a slight low level hum, so I'll take some chopsticks to the heater wiring at some point (although it won't move much).  It's not a ton of hum.  At normal playing levels, it's about 50dBA directly at the speaker and about 38dBA at the playing position so it isn't audible at all when playing.  Actually, I don't notice it even when I'm not playing, but I notice its absence when I turn the amp off.  It's not terrible, but I'll probably try and optimize it.  I've not built one of these before so I don't have a frame of reference, but I assume it can be improved.
Overall, it was a lot of fun.  I can see myself building a bunch more amps.  Finding a place to put them might be an issue, however.
« Last Edit: March 22, 2015, 07:27:39 pm by EL34 »
Re: My first amp build (18W)
« Reply #1 on: March 22, 2015, 07:16:18 pm »
Really nice looking amp!  :worthy1:  I'd never guess this was your first. Keep it up.
« Reply #2 on: March 22, 2015, 07:27:57 pm »
Looks good
« Reply #3 on: March 22, 2015, 07:32:17 pm »
 :worthy1:
That is a great build!
I just did my 1st designed board, kinda fun rolling your own!
again, great build!
Offline lkrasner
« Reply #4 on: March 22, 2015, 07:49:32 pm »
Single best trick I ever learned for working with electronics is drill twisting wires. just stick the ends of the wires to be twisted in the chuck of a power drill, hold them taught with your other hand, and pull the trigger. Works perfectly for this kind of thing, and it's so easy!
That is a beautiful build. hard to believe it's a first timer. Nice work!
Offline pickdropper
« Reply #5 on: March 22, 2015, 08:30:54 pm »
I actually did use a drill to twist the heater wires.  Without it, I never would've been able to get the twist that tight.  The difficult part for me was the interleaving of the wires as they met at each tube stage.  It was uphill sledding the whole way for me, but it did seem to work out OK in the end.
Thanks for all the kind words, guys.  I've built hundreds of pedals over the years, but it was nice to branch out and build an amp.  The only downside is that it takes a lot more space to store amps.  I'll figure out it, though.   :icon_biggrin:
Offline billcreller
  • 1934
« Reply #6 on: March 23, 2015, 12:02:21 am »
That's outstanding !! Great attention to detail ! :icon_biggrin:
« Reply #7 on: March 23, 2015, 09:02:07 am »
Very Cool  :thumbsup:
Offline supro66
« Reply #8 on: March 23, 2015, 10:40:18 am »
I built three so far
it is like eating a potato chip
you can"t eat just one  :laugh:
Offline pickdropper
« Reply #9 on: March 23, 2015, 12:11:05 pm »
I suspect this is a very accurate statement.  Already deciding what is next.
Offline TNblueshawk
« Reply #10 on: March 23, 2015, 02:33:20 pm »
Dave, if I may....
How about this one  :icon_biggrin:
http://home.comcast.net/~seluckey/amps/VAC15/ac15.htm
http://el34world.com/Forum/index.php?topic=16874.0;topicseen
I just need the iron (choke on back order) and I'm ready to roll.......
Oh, I've got a slight hum on mine but it really doesn't bother me. That or I'm too lazy to pull it so I tell myself it doesn't really bother me.
« Last Edit: March 23, 2015, 02:36:11 pm by TNblueshawk »
Offline zendragon63
  • Vacuum Packed Tone
« Reply #11 on: March 23, 2015, 09:20:25 pm »
Wowser, if ANY of my builds looked that spiffy, I would change occupations. You, pickdropper, have the patience of Job. And it shows. The VVR 'scaling' thing works pretty well with the 18 watt--recommended. Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
« Reply #12 on: March 24, 2015, 07:41:54 am »
That's a GREAT looking 18 watt. :-)  Very nice work.
Offline MakerDP
« Reply #13 on: March 24, 2015, 05:15:11 pm »
No need to twist the heater wires. Just keep them flat and parallel to each other and any other wires crossing at 90-degree angles.
Build looks awesome by the way.  :thumbsup:
Offline supro66
« Reply #14 on: March 25, 2015, 09:36:36 am »
It took me a year to build my first Supro 6420 and the cabinet
the Supro head and speaker is what I build the original Supro is below
I made the head to fit in the speaker if you want to go combo
The second Green Fender tweed 5e3 is on the floor I built and the other 3rd  Supro is on top
