September 18, 2026, 01:08:28 am
Hoffman Amps Forum image Author Topic: Reverb is sucking my signal?!?!  (Read 4307 times)
Offline hesamadman
« on: March 25, 2015, 04:15:57 pm »
I have solid state reverb installed in my 30 watt build. The reverb works, but the amp is waaay quieter than it is if I disconnect the reverb. And obviously lots less gain with the gain too. I know I shouldnt but I unhook the reverb while the amp is on (alligator clips) and its a very big difference. If I disconnect the pot ground.....all the signal comes back...and full amount of  reverb (uncontrollable obviously)
 Any thoughts?
« Last Edit: March 25, 2015, 04:44:41 pm by hesamadman »
Offline hesamadman
Re: Reverb is sucking my signal?!?!
« Reply #1 on: March 25, 2015, 05:04:25 pm »
i guess grounding locations are real funny. I have no idea what i did but seems to be working
« Reply #2 on: March 25, 2015, 07:23:21 pm »
Most likely you have some sort of bad impedance match.
Offline hesamadman
« Reply #3 on: March 25, 2015, 07:31:07 pm »
I THINK i had a resistor leaning over and touching its neighbor....
