August 29, 2026, 02:00:30 pm
Hoffman Amps Forum image Author Topic: B-52 Power Transformer Hookup  (Read 5817 times)
Offline dpm309
    • Matthews Amps
« on: April 01, 2015, 11:15:37 am »
I am replacing a PT on a B-52 AT100 and have a question on the primary hook ups. The original had a red and white wire and I am assuming the red is line and the white is neutral. The replacement (from B-52) has a blue and brown wire for the primaries.  Does it make any difference which way these are connected? The primaries are connected directly to the power switch. I am guessing that it does not make any difference but want to make sure.
Dan
Re: B-52 Power Transformer Hookup
« Reply #1 on: April 01, 2015, 11:34:42 am »
Should not make any difference.
Offline dpm309
    • Matthews Amps
« Reply #2 on: April 01, 2015, 12:50:27 pm »
Thanks Sluckey, that's what I thought.
Offline dpm309
    • Matthews Amps
« Reply #3 on: April 03, 2015, 12:08:22 pm »
Finally finished installing the new PT and everything sounds good. I do have a question about the built-in thermal fuse that B52 uses for their PTs. The old PT showed shorted windings in the primary but I am wondering if it was the thermal fuse that caused this. Did some research and found that thermal fuses are also used in some high-end audio equipment PTs and while it is possible to replace the fuse in some cases, it is not worth the effort.  What is the advantage of these thermal fuses since once they blow, the PT is virtually useless?
« Reply #4 on: April 03, 2015, 04:13:20 pm »
The fuse goes open, not short.
The idea is the fuse won't open until the PT is about to catch FIRE. Without the fuse, in another minute you could have had a hot stinking smokey mess in your hands, possibly setting the curtains or stage-sets on fire, panicking your customers, and in the end a useless transformer. The fuse just avoids the excitement. The problem happened before the fuse cut-out.
Offline billcreller
  • 1934
« Reply #5 on: April 05, 2015, 10:41:08 pm »
Sounds to me like the big fire & smoke thing will just make the audience think it's just part of the show  :icon_biggrin:
